unclematty
Gander Nxxxxx Position...
- Apr 3, 2003
Hi everyone,
I've recently started crossing the North Atlantic in a aircraft equipped with a multi-sensor FMS (NZ-2000). Which sensors are to be used/are you using to accomplish the 10 minute/GNE check?
Logic would dictate FMS position should be used....although if GPS should fail, it does make sense to transpose the IRS positions to the plotting chart.
Also, is anyone documenting winds/TAS/GS on the plotting chart as part of the 10 minute/GNE check.
Thanks for the insight!!
UM
UM
