Student Pilot Accident?
Beech1900
Member
Hello,
When i was doing my pvt rating part 141.I had a unforgiven accident. I would like some advices on my situation and concern. I was doing my SOLO x/c and landed at my first intended airport, refueled and took off to my second destination. Uncontroled field did my procedure , call outs ect. To make the story short , my plane was drifting to the left and landed off centerline. I saw i was to close to the gravel and full pwr went my plane tilt the left even more taking me to the grass. Airspeed was alive and i pull back on the power and tried to brake but no success. Finally i hit a ditch and bent the prop and nose gear. Right there i knew my career was over and quit but with some help of friends i decided to continue. I don't blame anyone but i sure do wished i was tought a crosswind landing Properly. Anyways 5 hours to build up my confidense back i managed to get my pvt license. Sorry for the story but i want to know what are my chances to getting hired in the airline. I had different opinions such as : You were a std pilot. But if anyone has any advice please let me know. Thanks alot.
Theres this thing on the back of the plane connected to these 2 pedals inside the plane. It's called a rudder. My advice is that you learn to use it.
Beech1900 said:
Hello,
Hey Clownpilot.
You never made ANY mistakes as a student pilot right? Give the guy a break. He said he wished he was trained properly. Apparantly he had a bad instructor. Some of us have had bad instructors and were not taught everything. I've been flying for 17 years, have never had an accident or an incident, but I can also tell you that I'm certainly not perfect. Are you?
Clownpilot
Yeah i think i know what that is. hmmmmmmmmmm i can play sarchasim too. It was a simple mistake ... ever heard of LEARN FROM YOUR MISTAKES!! Like i said dude i just want to know how will this affect my career.
This is what you call an "opportunity".
How you handle this in an interview situation will determine your future. When you get to the point of having sufficient time and experience that you have to explain this, get some interview counseling first. Typically, you will admit that you failed to properly control the aircraft, you explain about the additional instruction you made certain that you got, and how you taught your students so that they did not have the same thing happen to them.
Take a negative, and turn it into a positive.
Putting a cessna into the grass isn't the end of the world, not as a solo student.
'Kill all the clowns'
Listen to timebuilder and turn this into an opportunity. let me tell you about my situation.
It was pretty similar to yours -- I'll edit it for time though:
Second solo -- 20 hours or something - 17 knot crosswind -- touched down ok, fishtailed - ended up into the snow with bent prop and right wing. Mistakes -didn't take time to calm down and think to request runway that didn't have 17 Kt crosswind, Didnt go around (although it was after the touchdown that things got squirly) Landed too flat and didnt pull the mixture (thought about it, but hesistated because I thought I was going to keep it on the runway).
So what I now have is a leaning experience. On approach I knew about the wind and was very nervous. I had feelings of resignation (you've read about that hazardous flight attitude right). Then I though --'hey you can do this - make this plane straight (words of my Aussie CFI) and I did -- the landing was centerline ans was just fine - my instructor saw me land and turned his back - he thought I was ok. So did I -- I let the nose down which is when the wheelbarrowing / fishtailing started. I accidently keyed the mike with my deathgrip and my instructor, ATC and all heard my resulting four letter words. So, overcoming the resignation got me on the ground- thus I learned not to give up. I learned to take time to think about what is best- I should have asked for Runway 17 instead of accepting what they gave me 12 ( don't ask me why)
and I leaned that I should have gone ahead and pulled the mixture when I wa s getting near to the edge and of course I leaned the landing isn't over until the engine is off.
So now I have 250 hours, just got my Commercial and am working on CFI (at the same Aero Club) and don't have any crosswind issues. Oh by the way-like you- I didn't just step back into it. I was flying the next week, but yes I had to overcome some fear. But thats the key - I wanted to and I did. If you love flying and still want to fly -- then you will overcome this and be ok - trust me. Remeber the words of Manfred Von Richhofen ( who crashed on his second solo) 'The key to success is perserverence, ruthless ceaseless perserverance'.
Hope this all helps.
Shaun
Wise man once told me
In aviation there are only two kinds of people.
"There are those who have and those who will."
As I've read before, if it ever comes up at an interview; just explain and be truthful. All in all it was one hell of a learning curve to over come.
Good to hear that you got back in the saddle.
B1900, just listen to the positive advice!
I have had a nervous situation before! Back at that time I had about 15-18 hours, I was returning from a solo flight. I requested T&G's, was approved!
I made a couple OK ones, and on the 3rd or 4th one it got a little windy, no problem now! I touchdown somewhat off cntr and the airplane wasn't strait, if I had used the crosswind technique ever student is taught (or should be) I would have been totally fine, but once the airplane was headed off the rwy I hit that right rudder and the poor old 152 went up on 2 wheels, but thankfully I had the power in quickly and was correcting for the crosswind, that little situation sure scarred me, but thanks God nothing happened!
As a student pilot or beginner, you often will learn a lot of technique from personal experience, it is simply impossible for the instructor to teach you "everything".
All the best to you, if you have that lerking to fly heavy metal, beleive me, there is one waiting for you!
The great thing is you'll be able to pass this on to your students one day. Perhaps more students will understand that instructors who do not accept ANY drift off the centerline are not unyielding...you can truly say to them "been there done that and I don't want my student to re-live that experience."
In an interview I think you can turn it into something positive by letting the interviewer know that you are very intent on passing this experience on to your students. CENTERLINE, CENTERLINE, CENTERLINE!
Hello,
I wouldn hope that a future employer wouldn't hold an error that you made as a student pilot against you. If they did it would not only be extremely unfair, and I think a company I'd not want to work for. Listen to some of the more experienced fellows here and turn it into a positive, if asked about any mishaps that you had. Basically, what did you learn from it? How did it make you a better pilot?
Everyone, except perhaps "clownpilot" has made a mistake flying an airplane. Some are more serious and the outcomes much worse, BUT we all have screwed up in some way somewhere along the line. You may recall from the FOI that "learning is a change in behavior as result of experience". So, that is what we do when we make a mistake, we learn from it and do our absolute best not to repeat it.
"Clownpilot", you really ought to be ashamed of yourself for the sarcastic remark. I'll bet your crew just loved you as a PPC.
regards,
Ex-Navy Rotorhead
Sh!t happens
About the only thing I can add to the positive advice given here is that you should order all your records concerning your incident. Any kind of incident report, along with any NTSB records and FAA files. Review these records so you can be prepared to answer any questions. You have to answer the question on the app honestly about if you ever had any accidents or incidents. You have to answer all interview questions honestly and accept responsibility for what happened.
Above all, take every pain possible so it doesn't happen again. Student pilot accidents are uncommon, but they do happen. Best of luck.
Beech1900,
Hang in there. All the advice from the other members is very good and true (with the exception of CLOWNPILOT - there's always a bad apple in the bunch). Your career is not over at all. Like everybody else said in this thread, use this as a learning experience. I'm willing to bet, you'll always land on the centerline for now on and use your rudder, right?!?!?? This will help make you a better pilot and humble you for when you start flying bigger equipment. Just be honest when you explain this to the interviewer and turn it into a positive instead of a negative. Whatever you do, don't lie about it. Airlines have a way of finding things out, so be honest from the getgo. You're young and this happend early in your flying career...I don't think it would be toooo much of a problem. Keep your head up!!!!
boeingav8r said:
Beech1900,
Thanks to all for your advices!! I know that i have to tell the truth or explain if it comes up. But now that i'm seeing more into this bussiness and all the things thats goes around you pretty much have to watch your back in this career. Thats why i'm always doubting myself. BUT yes after the accident it made me a better, safer pilot no lie. I"m not perfect like clownpilot but who knows. Thanks to all.
Rudder?
By the way, this may be a moot point with most of the people here, but there is alot of talk about rudder to maintain centerline without regard to ailerons. If you are teaching a student to do the wing low method (aka sideslip), simply stated ailerons control drift and rudder maintains the longitudinal axis Parallel to the centerline. I can be on final 1,000 feet downwind of the centerline but still parallel to the centerline. Obviously, I'd need more aileron into the wind and more Opposite rudder to maintain the aircraft parellel. This all goes well until short final. The student usually doesn't recognize that, as the aircraft slows in the flare, more aileron and rudder needs to be used. Usually they hold it static and land off centerline. OR they mentally check out the minute the wheels touch. I usually see the yolk centered once the wheels touch, the wing getting lifted due to improper aileron use, and the student off centerline.
I bring this up because I've seen people who have earned their private who cannot execute proper crosswind procedure. Why? The minute the winds get to 6 knots x-wind ATC changes to the intersecting rwy. I try to take students to uncontrolled airports and practice on the x-wind rwy.
Just 'cause the max demonstrated x-wind is 17 knots in many light trainers, doesn't mean that it cannot be landed safely in higher (with due regard to keeping your own bravado in check).
Go out with your students when the winds are howling (even if it is a crappy day and you cannot get anything else done other than x-wind work).
