Strong Winds Move Parked Boeing 737
i love the guy trying to hold it
You don't have to be a hero! He'll be hearing from his union soon enough.
"So, where exactly is 'stop a 737 from sliding across the tarmac on ice using only my gloved hands' to be found in your job description George?"
Well, as you can see they didn't have a tug hooked up. This guy normally just shoves the plane outta the gate.
Rather impressive. He had that 320 moving at a healthy clip, especially considering it was with his freaking teeth.
I was thinking the crew could screw with and drag the brakes just a bit :) Then again if he found out about it, he might literally take a bite out of somebody's behind.
Was the relief FO at Heathrow preflighting the cockpit of a 777 before departure. A/C was parked at gate with tail directly into 60-65kt sustained steady winds.
It was a continuous mix of light and moderate chop while at the gate the entire time. About puked my guts out at the gate and I don't get airsick.
It finally dropped below 50kts sustained for takeoff. Really cool, full 777 for 10.5 hour flight and the mains broke ground about 3000' down runway (max/max power)
