AirBadger said:Heres a question, is it easier to set power when you're static? Single pilot in a King Air I would think it would be somewhat difficult from a rolling start to stay centerlined, move the throttle levers forward and be watching the engine instruments at the same time.
My understanding is that the 3 minutes is simply the number that the FAA chose to allow for certification...you can sit on the runway with the thrust levers full for 3 minutes before doing your certification takeoffs.El Bucho said:In Falcon 50 school they told us that unless you hold the brakes and set the power, that the DEECs won't let the engine provide advertised takeoff thrust for something like 3 minutes after you push up the thrust levers. Thus the reason to get on the runway and hold the brakes. Actually I'm confused. How does anybody actually do a "static" takeoff? Do you sit in the cockpit and make airplane noises or something?Just kidding...
EB
I think that may be an erroneous assumption...everything I've seen indicates power takeoff power set prior to brake release to make chart data.Mason said:If this has any bearing on anything I believe that all AFM T/O numbers are based on the power being set by 80kts.
Obviously, this isn't from the actual AFM, but I'm betting again that a reasonable facsimile exists in the AFM.Associated conditions...
...Both engines are run up to initial maimum take-off power and then brakes are released....
MauleSkinner said:I think that may be an erroneous assumption...everything I've seen indicates power takeoff power set prior to brake release to make chart data.
From my SimCom Hawker book:
As far as the power being set by 80 knots, this is probably listed as a rolling start technique, but that's a technique that takes you away from performance chart data.
Fly safe!
David
Snakum said:It did take a bit of getting used to, especially considering that the power levers on the B200 I fly are not rigged symetrically (left must be 1/2 - 3/4 farther forward for symetrical power). But I am very, very low time and I got used to it, so for most full-time pros it wouldn't be an issue at all, I'd think. The Captains I tag along with all do it quite smoothly, with no thought whatsoever.
Which type, if I might ask?Mason said:Ok, maybe my info just applies to a certain type.
