PowerCurve
- Mar 30, 2003
Minnesota Department of Transportation Aviation Rep.
https://statejobs.doer.state.mn.us/JobPosting
AVIATION REP
$ 21.08-$ 31.25 hourly, $ 44,015-$ 65,250 annually
Apply for this job Date Posted: 04/21/2006 Closing Date: 04/26/2006 Hiring Agency: Transportation Dept Division/Bureau: Central Office/Program Mgmt. Location: St. Paul Who May Apply: Open to all qualified job seekers Posting Number: 06DOT000192 Employment Conditions: Permanent, Full-time Work Shift: Day Shift Days of Work: Monday-Friday , 08:00 AM-04:30 PM Travel Required: yes Job Grouping: Const Facil Maint Mfg & Trans Classified Status: Classified Job Description: This position is located in the Department of Transportation's Office of Aeronautics. The incumbent in this position will inspect and license airports and manage a database of airport information using Microsoft Access. The person in this position will enforce Minnesota rules and statues pertaining to aeronautics and work with customer groups to improve the safety of airports and aviation-related activities. The incumbent will also pilot state aircraft. Minimum Qualifications: Extensive knowledge of Federal Aviation Regulations;
Basic knowledge of trigonometry which is used in runway analysis;
Computer knowledge and experience sufficient to manage a database of airport information;
Human relations and communication skills sufficient to prepare and present technical information to groups of all sizes.
Required Certifications:
FAA certification to operate high performance and complex aircraft;
Commercial Pilot Certificate with instrument rating or airline Transport Pilot Certificate;
1,000 hours pilot time and 500 hours as pilot-in-command
Current First or Second-Class Medical Certificate by the time of appointment.
Typically, the level of expertise required to perform this job can be achieved with approximately two to three years experience in one or more of the following areas:
Aviation safety and legal compliance inspector for a governmental agency; OR
Manager of a fixed base operation; OR
Instructor or professor of avaiation management or aviation sciences at an accredited university or college; OR
Aviation program administrator for a large education, business or governmental organization.
Preferred Qualifications: Multi-engine rating;
Seaplane rating;
Flight instructor certificates;
Rotocraft helicopter rating;
Knowledge of land surveying equipment and techniques;
Knowledge of geographic informational systems;
Bachelor's degree from a nationally accredited university with a major in avaiation or related field. Selection Process: The selection process is a resume-based, skill-matching process. Your resume will be entered into a database. The software program matches your skills with the skills needed to perform the duties of the position. If your skills match the required skills for this position, the department may contact you.
If you have already submitted a resume to this database within the last 12 months that clearly identifies your knowledge, skills, abilities, and experience, you do not need to submit another.
How to Apply: You are strongly encouraged to submit your resume through the online Resume Builder at <https://statejobs.doer.state.mn.us/ResumeBuilder>. You may copy and paste in your existing resume or let the software create a resume for you. You may edit your resume later should your contact information or experience change. The Resume Builder also collects your work preference information so we can match you with future job openings that meet your interests.
If you wish to apply with a paper copy, submit your resume AND a completed State of Minnesota Employment Application form to: Minnesota Department of Employee Relations (DOER), 200 Centennial Office Building, 658 Cedar Street, St. Paul, MN 55155. Be sure to indicate the posting number of this job on your application. The paper application is available on the State Employment Web and DOER web sites, at any state agency HR office, or by calling 651-296-2616 or, in greater Minnesota, 1-800-657-3974.
Contact for More Information: Deneen Clemons, [email protected].
AVIATION REP
Seaplane rating;
