Wroooooonnnng!ShawnC said:It won't, it adds more drag (and catch more wind) which would decrease your ground speed, which is what the GPS measures.
LAXSaabdude said:The added drag causes the aircraft to fly at a lower speed for the same angle of attack. Thus, since stall AOA is a fixed value, if you are right at stall AOA already, and you drop the gear, (flaps, as well), you can knock off a few more knots without going past stall AOA.
skeezer said:
Dropping the gear will NOT help you fly slower, just slow you down quicker.
Skeezer
