PC12Cowboy
Berry Beery Bad
- Nov 6, 2003
saltyworks said:when was this? DO you have a link with more info? I flew yeaterday from SEA to the east coast and had alot of ice in the climb.
PC12Cowboy said:Any one got any more info...was it AMflight going to reno????
And does anyomne know the pilot...and now just his family?
GravityHater said:Chute found distant from the airplane apparently.
"There was a parachute found at the top of Mt. Lincoln," she said. "It appears the plane has crashed behind the mountain."
----AND----
The four-seat plane was manufactured by Cirrus Aviation, the world's second-largest manufacturer of single-engine planes.
User997 said:Gravity, the airplane may have crashed further down the mountainside then the parachute did, even though they were both still attached. If the parachute was found separated from the wreckage, it also could've been sheered off on impact if enough metal got thrown around. Just a couple possibilities, outside of the idea that the parachute came apart before impact.
ALSO,
Did I miss where Cirrus became the 2nd largest SE aircraft manufacturers? I thought Cessna and Piper had that pretty well sowed up!?
GravityHater said:Check out GAMA's site. The figures for 2004 will come out on Feb 14. For 2003, Cessna shipped 841 units (includes jets) and Cirrus 469. Diamond 228, Beech 263 TheNewPiperCo 229. So, I guess yes is the answer.![]()
User997 said:Can't believe Diamond is producing as many as Piper.
LJ-ABX said:Amazing what can happen when you aren't looking.![]()
PC12Cowboy said:why would you with mormon girlies like that???????????????????![]()
PC12Cowboy said:Dx...only amflight pushes around here to make the flight...or redding aero....so I was curious...not stating fact
