FlyingToIST said:How about the reserve on the Brasilia side? I am hoping for PDX or any Kalifornia bases for the easy commute.
Thanks..
Ralgha said:Most of the California bases are either not an easy commute, only local trips, only reserve, or super senior.
Everyone I've talked to on reserve is breaking guarantee. You'll probably get more time at home holding a line until we are properly staffed, which doesn't look like it will be anytime soonMarineGrunt said:viper - for those getting reserve in ORD, any idea how much they're getting used? I have an interview coming up and if hired, I'm wondering what will keep me home more - reserve or line...
CFI2766 said:If awarded a California base out of training, about how long do you think it would take to get somewhere like DEN of SLC on the brasilia?
FlyingToIST said:Can someone drop a leg of SBA-SFO-SMF leg and start the work day at SFO for instance?
jacksjj said:PLEASE let me do well in my interview with Skywest.
Then, this information will mean something to me more than "That sounds cool..."
AGAIN... pleeeeeease.
8531 is PMI (Primary Marksmanship Instructor). It's only a secondry MOS. Semper Fi.Russ said:Grunt
I'm all too familar with 0311 as I was one waaaay back when. What MOS is 8531?
Sounds like an air wing range of the list.
I'm not quite sure about regular applications, but if you attend a group interview, you will walk away with a full interview date (if you are eligible to hire and not a total loser). I put my application in about a month ago and haven't heard anything until I went the group interview last week.dnkt said:How long does it take to hear back for an interview after you apply? I have 2500TT and 1300 Multi Turbine.
Solid. They're pretty strict on their hiring guidelines. But if you know someone on the inside.... who knows...maverick24 said:How firm are they on waiting 6 months to reapply?
rickair7777 said:Then quit d*c&ing around on the internet..go study your jepp plates and charts, or do some full approaches on MS flight sim. And Good Luck.
Thanks..
Reserve schedules still pretty much stink with PBS. If commuting, I'd go with FAT, since you'll probably hold a line more quickly than PSP.capt. megadeth said:How are typical reserve schedules in FAT and PSP? With PBS is it still 5 on 2 off or what?
Which place is better to go to as a junior captain?
Bluto said:Reserve schedules still pretty much stink with PBS. If commuting, I'd go with FAT, since you'll probably hold a line more quickly than PSP.
Now will you walk my stuff in to UPS or what?
Dave Benjamin said:PDX and easy commute do not belong in the same sentence. PDX is very much an underserved city. Flights are quite full and there are many commuters from several airlines. Commuting to reserve can be pretty frustrating. I'd plan on living in PDX if you're on reserve there. Once you get a line commuting is a little easier. Still you have to look closely at show and release times. If you have an AM trip that releases late you're looking at getting in the night before and going home the morning after. There may be other domicles that offer better commutability. As a general rule MX bases seem to have a lot of lines that start early and finish late so that's something you might want to consider when bidding bases.
PDX is viewed as a desirable area to live. SKYW downsized their PDX domicile forcing many to commute or move. Around the same time DAL closed their PDX domicile since they stopped doing the international flying out of PDX. Many of the DAL crews still live in the area. QX has a decent sized base in PDX. Many F9 pilots seem to live in PDX as well as a good sized contingent from WN. In the summer months commuting from or to PDX can be pretty tough. Even right now loads are pretty high because some carriers reduced service after Labor Day weekend.
rickair7777 said:No, that's not commonly done. I guess it wouldn't hurt to ask though. They will let you drop entire days if they have enough reserves available.
FlyingToIST said:Dave,
I live in SEA area, so in the worse case of not being able to make 30 daily QX flights and 8-9 company flights i can always drive down.. Do you think even with this condition will be harder base to get a line on?
Thanks...
WhatsUpNow? said:Can anyone give me a little heads-up on how reserve works. Reserve start times and duration (ie. 12,13,14 hr reserve periods) at my former airline we had 5am and 10am reserve periods, 14 hr reserve period. Thanks
