Tim47SIP
Serving for the USofA
- Dec 5, 2001
I just read a couple of publications (including Delta's) that have several changes in the DFW area. Either Skywest is slowly being withdrawn from DFW or they will be used for additional expansion to newer destinations. Here are the routes that ASA will replace Skywest aircraft on in the next 4 months.
DFW to:
DEN - 3 flights
AUS - 5 flights
SAT - 2 flights
PHX - 3 flights
MSP - 3 flights
and one flight for the following destinations:
DIA, ELP, HIA, MEM, MCI, TYS, SDF, ICT, OKC, and BNA.
ASA loses several destinations to Comair to pick up Skywest flying. **CENSORED****CENSORED****CENSORED****CENSORED**tytaco picks up all of the JFK expansion. Not sure what routes Comair is scheduled to replace Skywest with.
This equates to 26 flights. I don't know how many they still have in DFW, but with the last pull out of Skywest when they took over Delta's last bank out of SLC and now this, it looks as if they will only have a slight presence.
Any Skywest guys know if you are expanding in other areas? Or are you getting rid of the DFW base (if there was one)? Just curious.
On a brighter issue, Delta replaces ASA on three routes with MD88 service. SAT being one of them and also additional VPS service from ATL. Looks like things are starting to work the way it is supposed to with DCI building the feed and Delta taking over when the loads can handle the service. I hope it continues this way!
DFW to:
DEN - 3 flights
AUS - 5 flights
SAT - 2 flights
PHX - 3 flights
MSP - 3 flights
