For an aircraft type certificated for more than one pilot, you must attend recurrent every 12 mos. How about for a Single-pilot jet. Are the only requirements those listed in 61.57 (T/O and landings; BFR)?
Your insurance requires a sim every 6 months? Part 91?CE525 every 6 mos. I think it's more of an insurance thing.
I think the operative words are "Type Certificated". The CE500s and perhaps some others allow single-pilot operations, I believe under a Supplemental Type Certificate, but the aircraft itself is still Type Certificated for two pilots.For an aircraft type certificated for more than one pilot, you must attend recurrent every 12 mos. How about for a Single-pilot jet. Are the only requirements those listed in 61.57 (T/O and landings; BFR)?
That's right--I had forgotten about that. It's an odd wrinkle in the rule.The way I understand it, the category the aircraft is certificated under has a lot to do with it. Transport category aircraft will require an annual PPE. The Premier is certified under Commuter category and therefore does not require the annual PPE.
I couldn't agree more. I am against any turbojet larger than a BD-5J being flown single-pilot.And a dangerous one IMHO. We have owner operators and inexperienced jet pilots running around single pilot at 41,000 ft @.80 and they only need to pass 1 check ride. In addition to that, it took one individual meeting that description 3 trips to FSI to get through.
We will be operating ours 2 crew.
