pa31capt
- May 22, 2006
If the aircraft doesn't require more than one pilot as per the FAA; you can only log flight time if you're the sole manipulator of the flight controls.pa31capt said:How can the SIC be justified on later job interviews? Thanks
Nope. I don't think so. The problem is that the FAR defines "flight time" in a way that requires that you be either required crew or giving or receiving instruction. (See "flight time" in FAR 1.1 and "pilot time" in FAR 61.1). So that non-required SIC doesn't fit.FlaZoomie said:What about just logging it as multi and total time (flight) but not PIC or SIC?
