Should I start applying?
  • Thread starter Thread starter breds98
  • Watchers Watchers 4
breds98
Member
I have about 1100 hours TT and about 150 Multi. I will be graduating from college in May. Would this be a good time to start applying to any regionals/135 operators? I am just worried if I got a call, and had an interview they would be turned off if I said I couldn't start training until May. Any input would be greatly appreciated.
No man, apply now! It usually takes a couple months for the applications to go through. Most applications have a section "Available to work," or something like that. You enter MAY or "3 months" or whatever. Good luck!
You are way above the advertised minimums at a number of regionals. If you had gone to the Air Inc Job Fair at DFW last month, you probably would have gotten a job and been in class right now.
Just tell them your situation in the cover letter.
Hey, yip, if he had done that, he'd not get his degree and his whole career would be shot! ;) TC
717 wrong again, he could be an A-320 Captain at age 25 (see other thread) without messing around for four years. You don't need no stinkin degree to fly airplanes; the degree is only to impress some HR specialist. Do the degree on the side; fly airplanes if you want to be a pilot. Only become a pilot if you like flying airplanes. If you are in it for respect, recognition, prestige, or money, you may be disappointed.
I think 717 wrote that in jest.
Resocha that could be true, but it needed a response just in case, besides you have to use every opportunity to get the message out.
Apply now and if you don't have any good leads or a job by graduation, apply then too. Think about it...they are definitely not going to count applying early against you. Multiple applications can only be a good thing. Shows dedication.
