Short/Soft Field Takeoff
minitour
To save time lately, I've been just practicing "combo" takeoff and landings. One where I have to keep the nosewheel up but clear the 50foot obstacle too.
My question is (and I'll reference a 152):
For the takeoff...
Flaps 10, full back elevator, full power, accel to Vx in Ground Effect, clear the obstacle, accel to Vy, positive rate, flaps up.
When it comes to beginning the takeoff run, would you think it is better to come to a complete stop at the end of the runway and apply full power (short) or continue the roll and transition into full power (soft)?
I can see VERY logical reasons for both ideas.
On one hand, you've got trees at the other end of the field, bad time to not be developing full power in the engine.
On the other hand, you've got a soft field, bad time to let the nosewheel "settle" into a hole or depression in the turf.
For the landing:
Full flaps, 55 down short final, keep the nose off the runway.
If the field is that short and soft, is it better to slam on the brakes like you would on a 1600' asphalt runway?
I can, again, see logical reasons for both ideas.
If you don't slam on the brakes, you're going to slam into a tree.
If you do slam on the brakes, you're going to throw the nose into the ground and risk flipping it over...plus you've got that soft ground slowing you down.
I realize there are "book values" for how much a soft field increases your takeoff roll and landing distance, but I figured I'd ask the "real life" pilots about "real life" situations.
Any input would be helpful. Thanks a ton!
-mini
Reality check. Most short fields are soft, and most soft fields are short. Many of them are surrounded by obstacles.
The reality is that very often, there's really no difference between short field and soft field; it's the same field.
Therefore, your goal is to get off the ground and into ground effect quickly, without bogging down, then climb above obstacles.
Short answer; do whatever is required and don't ding the airplane. If it's soft, keep it rolling. If it's not soft, you can do a braked start. If it's soft, keep the aircraft light and get it in the air; if it's not soft, then get it fast, quickly. Adapt to the specific surface and surrounding conditions, and do whatever is required to make the airplane fly.
mmmmmmmm'kay.....so use some judgement?
That's all ya gotta say, "use some judgement".
No need for the smartass "reality check" I realize most soft fields are short, which is how I convinced the instructor that it was worth it to practice said takeoffs and landings...just looking for an opinion on which factor was more important. Obviously the most important factor is judgement and common sense...that's all ya gotta say...
-mini
There is no PTS for a short/soft field. The procedures are not compatible. It is a recipe for disaster to attempt a soft field procedure on a short runway.
Avbug's spot on. However, for the purposes of the checkride...
'Sled
Mini,
If you don't like the advice, don't ask. You didn't get a bill, did you? Apparently you aren't aware that most soft fields are short, and visa versa. You just learned something. My post didn't say "use good judgement" because that wasn't what I said, nor what I intended to say.
Read. Think. Shut up, and think about it some more. You might just learn something.
And yes, short and soft are most certainly compatible...of necessity. Reality.
There's the Big-A Numero Uno reason that most pilots and instructors of today cannot fly/adapt to the real world. Instructors and, consequently, students don't teach/wanna learn anything but the PTS.
There is so much more to teaching how-to-fly than the PTS.
Since the real-world act of "using common sense & good judgement" in negotiating a soft/short field would be very SUBJECTIVE in evaluation, the FAA sidesteps this one and tests the procedures seperately and hopes you can put them together in the real world as Avbug suggests.
Mini is actually interested in learning something that is NOT in the PTS - one of a dying breed. Keep it on, Mini;)
Be conservative
Nose hair, I learned to fly in the military, we learned to fly in a very tight procedural envelope, and this allowed us learn quickly with low flight time and allowed us to gain experience without killing ourselves. I use the same procedures when teaching civilians. I have instructed in my C-150, the C-150 is under powered. I did not want my students killing themselves by trying something they were not certified to do. I had a 2200' grass strip I used, it had a fence at the end and a 30' tree off to the side. Using short field technique you would clear the tree, on the same runway using soft field technique you could barely clear the fence. I told them to stay the heck away from short unpaved strips. New pilots should not be taught to put themselves in situations where they may be in over their respective heads. As a pilot gains experience they will be more capable of recognizing how an airplane will perform. At the same time and near where I instructing 3 people were killed when a new pilot attempted short/soft procedure in a fully loaded Cherokee, and later another pilot ran off the end of the same runway after attempting a soft/short procedure. The field collected water after rainstorms and was almost swampy; it was a true soft field. Most grass strips are not true soft fields, and short field procedure can be used.
I teach on short fields to apply full power while holding the brakes. I also teach my students that full power while holding brakes is not solely to increase acceleration after brake release.
While full power is applied, the student should look at the engine gauges to make sure everything is reading correctly/normally, and should also be listening to the sound of the engine to make sure is sounds normal.
Fly_Chick said:
I teach on short fields to apply full power while holding the brakes. I also teach my students that full power while holding brakes is not solely to increase acceleration after brake release. While full power is applied, the student should look at the engine gauges to make sure everything is reading correctly/normally, and should also be listening to the sound of the engine to make sure is sounds normal.
That technique is all well and good and is fine for training and for the checkride. However, in the real world that Avbug mentioned, you'll make the aircraft owner's and mechanic's "A-List" when you do a static run up to full power prior to brake release. Reread his post. In the real world, short fields are usually soft and soft fields are usually short. These types of "runways" usually have a plethora of things like gravel, etc. that do wonders for propellers. I've flown off of many short/soft fields and as Avbug said, the proper technique is usually a combination of the techniques. Just some thoughts.
'Sled
Note that some fields are softer than they are short. Many years ago, when I was still a low-time private pilot, I had to make a precautionary landing in a recently plowed farmer's field in my C150. One of the fuel caps had come loose and was banging around on the wing. I was watching the fuel siphon off the back of the wing and wondering if I would make it to airport before the fuel tanks were sucked dry. I was right over a huge farm, however, so I elected to land and replace the fuel cap. By the way, my landing roll was very, very short since it had rained the day before.
Although my landing was good, I did not keep the nose up on the take off roll and got the a/c bogged down in the dirt (it was are really, really soft field). So I hike the mile or so to the farmer's house, explain my situation and he uses his tractor to tow me to a higher, dryer part of the fiield. This time, my soft field technique was better and I made it back to my home airport.
The lesson I learned was that improper soft field technique can prevent you from taking off at all if the field is truly soft.
I agree with the other posters that most grass strips are not really soft fields, but are more likely to be short.
avbug said:
Mini,
Didn't say I didn't "like" the advice, just the way it was presented. You kinda get high on yourself sometimes man...there was no need to get smart assed with the "reality check" comment. Other than that, your advice was terriffic and I agree 100% with it...just not the smart-ass delivery.
...and there you go again :rolleyes:
nosehair said:
Keep it on, Mini;)
Nah...aparently I need to learn to read the PTS and just learn to pass the test...right? Thanks though for the kind words and more....normal delivery :)!
Anyway...thanks to everyone (including you avbug...like I said, not the advice but the delivery...it's called tact) for the advice/input! Much appreciated!
-mini
"like I said, not the advice but the delivery...it's called tact) "
You mean like biteing the hand that feeds you. Every post is a gift, the value of the gift depends on many things. If the gift is food for the starving (or information for the unknowing) is it tact to say, "I'll take the food but next time smile when you give it"? You take the gift but comment on the wrapping paper?
Mini, the first post I read of yours was when you said "I would not piss on a FAA Inspector if he were on fire". An intresting comment from some one who most likely never worked with or even meet an Inspector in his then entire 100 hour pilot life. You ask many questions, IMHO a sign of intellegence but you make statements that only an idot would make.
Avbug is this a lost sheep or a lost cause?
JAFI
Watch Out. When The Rath Of Mini Unleashes....hollllleeeey Shiaat.
HA! We rock, gotta love the egos all around. ("By the way, I'm a pilot!")
It's a heck of a fraternity.
With respect to the short/soft field.......... if they can use the plane again.....
If you can show me where I said that, I'll gladly retract. Do I believe in volunteering information that could fry my ass? Nope.
Is it possible I spouted off that comment? Yeah...I'll be the first to admit I screw up. I'm not making claims that I'm perfect, know everything or that I'm not an @s$hole...I'll admit every one of those. So if I said that, I'll retract it...but for the life of me, I don't remember it.
JAFI
Statistic in the making, right?
Like I said...not that I didn't appreciate or agree with the advice and input...just the manner in which it was delivered. I didn't see a need for the "reality check" comment to start off the post.
Who knows...maybe he didn't mean it to be smartassed...and if that's the case then I apologize for taking it out of context and (aparently) starting a pissing contest...it's quite possible that I didn't hear the tone in his voice by reading the text...and if so, I'll admit I effed up. Is this the case?
-mini
I'm going to agree with Mini. And on "reality check" grounds.
The reality is that the way a message is presented =does= have an effect on the content. Good knowledge, delivered badly, is going to find a limited audience and receive a bad response that, if not necessarily deserved, is definitely to be expected. Good teachers all know that.
