ImbracableCrunk
Unregistered Un-User
- Feb 5, 2003
tindriver72 said:Same at Shuttle America, that is when they had them. Why would you want it on anyway?
AutoBus said:Hit the G/A button before takeoff and get a solid 10 nose up pitch reference, then you are pretty much perfectly setup for a v1 cut, or any engine failure in the initial part of the climb. there may be some speed variation at first but you will most likely end up somewhere around v2.
Alchemy said:Expressjet doesn't have Saabs? But I thought anything smaller than a 737 with a globe on the tail had to be pwned by Expressjet.
livin'thesim said:As an aside, I've seen crews flopping all over the place trying to get the FD to command the correct target performance. Fer cryin' out loud, take her to 1000 ft on the big fat ADI they give you. It isn't that hard.
livin'thesim said:Re: Generators, 600A transient, 400A Cont, if I remember right.
