If its a re-occuring problem, then its not likely to the turbo's problem. There are two check valves in the oil supply/scavenge lines. If they are mounted backwards, or obstructed, then you wouldn't get the necessary lubrication to the unit and that would cause premature failure.
If the induction or exhaust system is compromised (leaking), then that would be indicative of full power on take-off, but not at critical altitude. You should be able to get full boost to 12,500 pressure altitude.
