Sawing the MD80 yoke!
typhoonpilot said:
The 80 can be a handful when it is gusty but that looked like bad technique, the guy was over-controlling. The sound at the end sounded like a radio altimeter was set for 0.
TP
RA, that's right.
Yeah, from 50' down, he was a bit wicked on the fore/aft movement of the control wheel.
Poor technique
I used to fly with a guy who was WAY worse than that. Even on a relatively calm day, you'd have to keep your hands well clear of the yoke when he was flying. He was a maniac on the controls, but he was very experienced. I always felt it was poor technique, and I think he thought I was lazy or laid-back on my landings because I just used minute adjustments to get what I wanted. I'm serious, this guy burned some calories below 50 feet AGL, and he was a check airman. I never could figure out why he did it that way.
It also looked like he cracked the reversers before the nose was down. That's a very good way to scrape the clamshells on the runway in that airplane.
There are quite a few people out there who jack the yoke on short final. The control responses in the -80 are so slow that you are just cancelling out all the inputs. I've seen it done in the GV (way too responsive for that kind of behavior!) and you could REALLY feel it. I always try to see how little input I can make all the way down.
It's just a bad habit--I remember almost getting into that habit myself. Some TWA Captain b!t@h-slapped me and I never looked back. :D
I always found the -80 was very stable on approach--you just had to realize it had pretty slow control response and needs a BUNCH of rudder to kick the nose straight in a cross wind. JMO.TC
I think pilots carry that over from other aircraft that have a lot of "stiction" in the elevator cable runs. Some planes have high breakout forces, so getting wild in the flare keeps you "in the loop".
It is still bad form.
Actually, that type of pilot control is well known in the flight test/certification world. A pilot that does that would be classified as a "high gain" pilot, tending to be reactionary, rather than anticipatory in their control inputs. A pilot that is "high gain" has a much higher probability of encountering what is now known as "APC", but more commonly referred to as PIO.
Looked ok to me, like he had a crosswind on approach though. I guess the guy was overcontrolling you could say, but it looked like he got the response from the plane that he wanted. Move the control wheel a lot and back off, or move it less and wait. This is an original fly by wire plane you know, 1/8 inch cable. No hydraulics (except for stall pusher and rudder for engine failure) and the cables move control tabs, not the surfaces. I only flew it (it flew me rather) for 60 hrs but the feel in pitch was spongey and springy, in roll it was similar but the rate increased quickly once the spoilerons deployed. The -80 used to input roll and pitch like that with the AP flying an approach. That's about when I would say george has had enough and disconnect.
When I was at Mesaba I noticed that a lot of the new Avro captains that had just transitioned from the Saab did the same thing.
You could be right about the necessity to fly this way in the -80 with no hydraulics, but when I encountered this phenomenon we were flying 737's (200's). I think it was just a bad habit for this guy, because come to think of it, he had come out of C-130's and I'm sure the 130 is quite the beast.
I was just glad I never had to make any radio calls for him below 100 feet, because I sure as heck would have broken a wrist or some fingers going for the PTT.
