Safe areas of general aviation
flyf15
I've been in the airlines long enough to have lost most of my connection with general aviation. I've been hanging out at the local airport engaging in hangar-talk with the locals and I'm starting to miss it. I'd say my biggest turn-off is the lack of safety compared with airline flying.
So, my question to all of you general aviation experts, what is the safest area of general aviation that you know of? How safe are gliders? If you were in a position such as mine and wanted to get back into it but didn't really care which part, which would you pick?
Somebody said a J-3 Cub can 'just barely kill you'.
Seriously, I have to think that flying something like a Cub or other certified two seat light plane out of a small country strip in flat terrain on nice days is pretty darn safe.
Now some of the imported LSAs are a different kettle of fish. But that's for another thread.
Some might perceive a verdict of lack of safety in general aviation as a mark of arrogance.
I certainly would.
I would, because it's as safe as you make it. If you're looking down your nose at general aviation as somehow less safe than your narrow, small world, perhaps it's your own perception.
Do you fear general aviation, or fear yourself? The determining factor is you.
I certainly would.
I've been in both worlds, and can say that I feel safer in the airline world then I do in the GA world. Statistics prove that. You get these weekend warriors that fly twice a year and are completely clueless once they get in the air. Very scary.
Safe as YOU make it.
GA can be as safe as YOU make it. Look at the history of GA accidents, avoid those things that cause GA accidents. Simple things. One of the major causes of GA accidents is running out of gas. Make sure you enought gas when you take off. To fly a GA airplane without dipping the tanks, would be scary in my mind. VFR into IFR conditions when you are not Inst rated, does that fit? I feel perfectly save flying my C-172 around.
Before this turns into a bashing exercise in one of the famous flightinfo unprofessional free for alls, there's no need for name calling. Flyf15 asked a simple question, and the answer is just as simple; flying is as safe as you want to make it.
Take that 172 flight, for example. You can make it in many ways, some of which are not at all safe, others are, but only so far as you allow the to be. You fly from A to B. You do it at night, and when you have a failure of your single vacum pump, single generator, or other problems with your minimal equipment, you have instrument losses, system losses, failures that have no backup, and if you have an engine failure (never a matter of if, but when), you can't even plan a proper forced landing because you can't see anything.
Modify that a little. You're over a metro area with good highways beneath you, it's late, light traffic, you know the roads, you know the powerlines, you know the surface, and you are confident that you can make a forced landing if you need to. There's more light in your cockpit than you really need due to all the light from below. You don't need any instruments, it's as good as day below. You make the flight at night no differently than you would in the daylight, execute a dozen night landings at your favorite runway, and enjoy a ride home in smoother air than the daytime. You find it relaxing, spiritual.
Two sides of the same coin, all in how you elect to make the flight. You make a cross country, take three quarter tanks, plan on using a full half tank, so you'll arrive with quarter tanks. Well enough, you have your reserve, but lo and behold, you didn't catch the wad of leaves put in the tank vent by the leaf cutter bee, and you got an uneven fuel flow. By the time you're nearly to your destination, you have plenty of fuel because the engine runs dry...you're sucking air feeding from the tanks when it's not really feeding, and one tank has run dry. Change that scenario to no mechanical issues, but the unwise decision to run a tank dry before switching...and now you can't get the engine started. There are ways to make it safe, and ways to not make it safe.
In the airline world, you have small windscreens and large areas to cover. Youré in and our of metro areas with high traffic, then up into the "safety" of the airways. You seldom look out the window, seriously scanning for traffic, at cruise altitude. But you also know that when you first got TCAS, you were shocked at the amount of traffic that's out there that you don't see. Now you're jumping into a light airplane equipped with what you bring; your two Mark I Eyeballs, and a neck to swivel them about. As safe?
That's up to you.
Certainly the radio and ATC won't find that traffic for you. That's up to you. Certainly TCAS won't help you, because you won't have it. Nor should you be heads down any more than necessary; look for that traffic as though your life depends upon it, because of course, it does.
Your airliner has aircraft data by which you fly. You have much of it done for you, but you also do some yourself. No reason why you can't calculate the same TOLD data along with your weight and balance. Some call it overkill in a light airplane, but it's not.
Think about the notable midair collisions over the past few years...how many of them have been in controlled airspace, while talking to ATC and participating in the system? The vast majority of them. Did this make them safer? Of course not.
In general aviation, the type of "accidents" continue to be boringly familiar; they stay the same. Infrequently is the airplane or gyroplane or helicopter or balloon or sailplane at fault. Invariably, it's the pilot that runs out of fuel, continues VMC flight into IMC, strikes terrain while flying low, fails to properly preflight, loses control in convective weather or in ice where he or she shouldn't be, or the ubiquitous and freakishly popular stall-spin during the turn to final (or turn back to the runway after an engine failure, take your pick). The list goes on. The common thread is that in each preventable occurance, the deciding factor isn't the safety of general aviation, but the pilot. How safe is it? That's up to you.
I'd like to ask a question that has bugged me since the "single engine IFR" thread. How does a GA pilot SAFELY build IFR experience, especially if single-engine IFR is considered dangerous by many?
Aviation is inherently dangerous. Some may not agree, but I see it that way. Just like everyone else has previously stated, GA is as safe as YOU make it. The problem with that seems to be that most amateurs lack the ability to conduct aviation related activities with the professional mindset required.
There is absolutely nothing that makes single engine flight more dangerous than multi engine flight. Both configurations have their Achilles heel's, so to speak.
It can be as safe or as unsafe as you make it.
Day VFR can be flown in a manner that is completely unsafe.
Conversly
Night IFR can be flown in a manner that is well within what most of us call safe.
The difference between the airline world and GA is personal involvement, and controll.
At Delta, a dipatcher prepares the flight plan, maintence did the A check, the ground crew loaded the freight, ect.
All these profesionals are working hard to allow you to make a safe flight. However each one of those people hold the opportunity to make an error, that you as PIC have to catch. You also have the duty to fly the trip if it can be leagely and safely done (200 and 1/2 mile in blowing snow). Would you have a clue if a mechanic forgot the saftey wire the squib on a fire bottle?
In GA it's all on you, you have to do everything, however you have all the controll.
You make the plan, you preflight the much more simple aircraft, you load it, ect. You can get involed with the maintence if you want (it won't save you any money). You can add equipment that you feel will improve your safety in the air. You can decide to not fly if you think it would push your idea of what would be safe.
If you move yourself faster than a walking pace it has risk's. I myself feel safer flying then driving the DMV or DOL should replace their name on the building to "Box of Cracker Jack's"
Airline pussies
I have had a lot more friends who have died flying small airplanes than airliners and it doesn't look like that statistic will be reversing itself any time soon.
Yeah, I'm a *************************. But I'm also simply someone who wants to engage in general aviation with no "need" to do so... purely as a fun hobby. A fun hobby that is as safe as it can be.
You make no sense.
I say go rent a 172... Cherokee... whatever... and depending on how long it's been, an instructor as well. Go shoot some landings, see a sunset, whatever. Get back into flying.
You do what you can to mitigate the risk.
I'm in the process of puchasing a J-3. Although I've got hundreds of hours in this particular airplane, J-3's as a whole have a poor accident rate, especially in the fatalities per 100K hours flown.
So, I can sit on the sidlines, fly the Boeing for cash and miss out on enjoying many of the things that attracted me to flying in the first place. Or, I can (and have) purchase seat belts and shoulder harnesses that will be installed before I fly the Cub. I will also exercise extreme caution in the low speed area of the envelope when close to the ground, as that's where many Cub fatalities occur.
You're the PIC, you accept the amount of risk you're willing to based on your abilities, knowledge and the rewards.
I no longer fly single-engine night or IFR. And I used to.
Airline Pu**ies?
Whatever, buddy.
"One of the major causes of GA accidents is running out of gas."
Really? Now where did you hear that? I thought running out of gas was a pretty rare(but inexcusable) reason for GA crashes. I read somewhere that it was one fuel exhaustion accident a month(that involved fatalities?).
What is the name of that report that comes out every year on GA accidents that would have more reliable info?
Avweb I have a ton of respect for your insights and experience. But what about a situation like the Ellmendorf(?) crash in Alaska, where four engines stop because of bird ingestion after takeoff? I can think of scenarious where the universe manifests things that are not in your control, at the worst possible time.
Of course, you may be ultimately right, just fly a small cub out of a flat strip somewhere on beautiful days and always have an out.
Not necessarily fatal, but go throught the NTSB data base there are a ton on SEL GA airplanes that go down due to fuel stravation, contaminated fuel, improper fuel, no fuel in the tank feeding the engine with the gas gauge selected to the full tank. My insite into this came from an GA Aviation Safety flyer I saw back in the 90's
I think it's reasonable to say that anything fun entails risk. All you can do is train properly and approach every flight you take professionally. If the fear of something "bad" happening outweighs the enjoyment that flying brings you, then you will never be able to truly appreciate the freedom of flight. Airlines achieve their great safety numbers through rigid, standardized training and procedures. They don't get to stop by many pancake breakfast fly-ins, though.
There was a Neil Young song that included the lyric, "it's better to burn out, than it is to rust..". I think about that sometimes, when people ask me the question about flying being dangerous. Appreciate being able to fly ! It's supposed to be a gift, not a burden.
No offense, but you thought wrong.
Go to NTSB.GOV and set up a search for accidents involving fuel exaustion. From 7-9-07 to 7-12-05, you'll find 74 accidents where fuel exaustion was the the probable cause. That works out to a little over three a month. Historically, this is low.
Spend a little time looking around the NTSB site at accdents in general. Although most people consider themselves talented pilots, youll be amazed at how many stupid and inventive ways we find to bend metal.
You're not one of those folks that tells his students that flying is safer than driving are you?
:D
