kilroy
http://www.filecabi.net/v
- Jul 10, 2004
All this talk of RVSM and its hard to believe its actually here. So how much of a cluster F()ck do you think 01/01/05 is going to be. Better yet how many operators are not going to be ready . My current employer will not be RVSM qualified by then . They are waiting for the prices to come down . Mean while I,ll be stuck in the mid 20 flight levels like all the rest of no certified aircraft and all the turbo props.. Now thats going to be a mess all these .80 airplanes flying around at turbo prop altitudes
New Equipment Suffix For FAA Flight Plans
Reduced Vertical Separation Minimum (RVSM) will be implemented in Domestic U.S. airspace between FL 290-410 (inclusive) at 0901 UTC on 1/20/05.
Effective 1/5/05, when filing an FAA Flight Plan, with the exception of operators filing through DUATS and Flight Service Stations, RVSM-compliant operators/aircraft are expected to file /Q or /W, as appropriate, for flight between FL 290-410 (inclusive).
Effective 1/20/05, RVSM-compliant operators/aircraft must file /Q or /W, as appropriate, or be denied clearance into RVSM airspace.
A full explanation of the revised equipment suffix table is located in the "Area of Operations Specific Information" section at http://www.faa.gov/ats/ato/rvsm
