RVR Question..Go or No Go?
dueguard1
ROTT MAN 4 LIFE!!!
While taxing to the active...the touchdown zone RVR goes INOP... Can I still depart? (Under 121, Hypothetically if it were crap for weather)
Depends if there are other RVR sensors on the runway. If not, then you have to resort to prevailing visibility I think. Or, those of us lucky enough to be in the right seat look over to the left seat and say "can we go?":p
And you'll usually get a befuddled look and "I was hoping you would know" response.
And I'm not knocking Captains here. We sat on the taxiway for 20 minutes in AVL discussing our options and where to look them up with another ASA crew waiting on the same taxiway. Thankfully the weather came up or we'd probably still be sitting there.
Look at the back of the 11-1 or 10-9 page in the Jeppesens. Normally you need 1/4 mile/1600 RVR vis for depature, at my airline we can go down to 600 RVR if you have atleast two RVR's and some runway lights/markings. If you have three RVR's available, and one out of the three RVR's are inop, you can still go (provided the others are reporting >600 RVR); if they are all working and one out of three is reporting <600 RVR, its controlling and you can't go.
I'm guessing this varies for each airline, however. In short, it depends on the airport facilities and how bad the weather is if you can go or not.
~wheelsup
If the winds are favorable, takeoff the other direction if the RVR for that end is at or above mins.
Your Ops Specs answer the question. Most will allow you to depart with the TDZ RVR inop because you can substitute MID RVR. There is one thing you have to keep in mind. Just because it's legal does not mean it's safe or prudent. Legally I could depart with 1600/0/0. Does that mean it's a good idea?
True, but your Jepps should be tailored for your airline. I look at the Jepps to see if I can go, not my Ops Specs. As someone said, the back of the 10-9 tells all. BTW, enlighten me on how you can takeoff 1600/0/0. I don't know if you're 91 or 135 or 121, makes a difference. For me, if all three work we couldn't go in that case. Plus I've never seen that much variance in the RVR units, a few hundred feet difference is as much as I've seen.
RVR ?'s are always a gray area, with all the "buts" and "ors". Basically you need 2 - and if there are 3 operating you have to use all of them , and the lowest one is always controlling. I heard of a DAL capt who got busted cuz he needed 600 rvr, and the reading was 6x6x5 - he thought he could go since 2 out of the 3 said 600. lowest one is always controlling!!
I have never seen a 10-9 that was tailored for a specific airline. The company specific page where I work is a 10-7 page, and at our company that does not give takeoff mins. We have the ability to reduce what is on the back of the 10-9 if certain criteria is met, which is specified in our ops specs. Unfortunately we have a few that either don't know this or don't want to look it up, so they will sit and wait for the RVR to come up to what is listed on the chart even if they meet all of the requirements to reduce it.
I didn't know that Jepp prints individual charts for different airlines and general part 91 users. I thought we were all looking at the same material.
