rvr and vis question
  • Thread starter Thread starter cxcap
  • Watchers Watchers 3
cxcap
Heard about this question being asked at an interview and cant seem to find the answer. Required vis for the approach is 1.5 miles vis. ATIS is reporting 2 miles vis. We start the approach and tower reports RVR 4000 for the runway we are shooting the approach to. Can we continue the approach since RVR is not listed in the minimums box on the plate?
Under 91 you certainly can, however I don't think that is the jest of the question.
Under 135 and 121 you can continue your approach if inside the Final Approach Fix (FAF). However, if you're outside the FAF you can not accept the approach clearance, because 4000RVR is less than 1 1/2 miles. There are some conversion tables in the front of the Jepp and in the AIM that clarify this issue.
These tables basically state what visibility you can use if RVR is not available, but it only stands to reason that you can also do the reverse if sm is not available.
I would imagine this question is more directed towards your general aviation knowledge than the specifics of RVR vs. vis. The interviewer was probably just seeing if you knew that at 4000 RVR you're probably not going to see the runway if the approach requires 1 1/2sm.
I dont have time at moment but will try to find reference: It could be 121 or even op spec but I know somewhere I have high lighted that RVR is controlling and if available would have to convert vis to rvr
Also will look for reference but if tower updates wx to your specific ry then that is controlling
