Runway weight limit
EMBpilot
Guys/gals,
I heard somewhere that performance calculations of the max. TO weight limit include a requirement that the airplane (all engines operative) has to accelerate to V2, gain 35 feet of altitude and still have 15 % of the runway left at that point.
Pax, sched. Part 121 airlines.
If this is correct could any one give me an FAR reference?
Thanks a lot!
EMBpilot said:
Guys/gals,
Thanks a lot!
§ 25.113 Takeoff distance and takeoff run.
(a) Takeoff distance on a dry runway is the greater of—
(1) The horizontal distance along the takeoff path from the start of the takeoff to the point at which the airplane is 35 feet above the takeoff surface, determined under §25.111 for a dry runway; or
(2) 115 percent of the horizontal distance along the takeoff path, with all engines operating, from the start of the takeoff to the point at which the airplane is 35 feet above the takeoff surface, as determined by a procedure consistent with §25.111.
(b) Takeoff distance on a wet runway is the greater of—
(1) The takeoff distance on a dry runway determined in accordance with paragraph (a) of this section; or
(2) The horizontal distance along the takeoff path from the start of the takeoff to the point at which the airplane is 15 feet above the takeoff surface, achieved in a manner consistent with the achievement of V2 before reaching 35 feet above the takeoff surface, determined under §25.111 for a wet runway.
(c) If the takeoff distance does not include a clearway, the takeoff run is equal to the takeoff distance. If the takeoff distance includes a clearway—
(1) The takeoff run on a dry runway is the greater of—
(i) The horizontal distance along the takeoff path from the start of the takeoff to a point equidistant between the point at which VLOF is reached and the point at which the airplane is 35 feet above the takeoff surface, as determined under §25.111 for a dry runway; or
(ii) 115 percent of the horizontal distance along the takeoff path, with all engines operating, from the start of the takeoff to a point equidistant between the point at which VLOF is reached and the point at which the airplane is 35 feet above the takeoff surface, determined by a procedure consistent with §25.111.
(2) The takeoff run on a wet runway is the greater of—
(i) The horizontal distance along the takeoff path from the start of the takeoff to the point at which the airplane is 15 feet above the takeoff surface, achieved in a manner consistent with the achievement of V2 before reaching 35 feet above the takeoff surface, as determined under §25.111 for a wet runway; or
[Doc. No. 5066, 29 FR 18291, Dec. 24, 1964, as amended by Amdt. 25–23, 35 FR 5671, Apr. 8, 1970; Amdt. 25–92, 63 FR 8320, Feb. 18, 1998]
