RJ to Widebody
Stifler's Mom
MILF...MILF...MILF
OK...was reading over the CAL thread where there was a discussion about Regional pilots being placed into narrowbody and widebody aircraft.
What is the biggest challenge to a pilot going from an RJ to say a 767 or 777? Is it the handling of the aircraft itself, the type of operations that a widebody sees (overseas, etc), neither, or a combination?
The hardest thing about the transition is deciding what to have on the menu!!! Other then that it is an airplane.
The biggest challenge is dealing with a FA to Pilot ratio greater than one.;)
I transitioned from a BAe4100 to an L1011.
It was different, but it's not that big a deal. Having FMS experience will be a plus.
As long as you can work an FMS and a FD there really is no problem in transitioning from RJ to widebody. Although the speeds are the same there is a lot more momentum to consider, especially breaking out at minimums on a non-precision approach with a x-wind -- I think that's the biggest challenge.
Of course you won't be taking off or landing for years if you get the 777. You will be an international relief FO for the forseeable future. All your currency will be in the sim. As long as you can find the transmit button and fasten a seat belt it will be a breeze...
Momentum management and staying ahead of the airplane, then the glass stuff. Let the magic supplement your skills - not vice-versa.
Toughest thing is physically placing your body on the centerline, or so it will seem, else you will be landing right of centerline as f/o. The other thing is to sstart flaring when the GPWS says "30", rather than driving it onto the ground as you do in the rj. Understanding forgein controllers will taake a couple of trips to get used to as well.
VNAV.
manageable but a threat to the newbie.
respectfully.\,
fv
Good advice. The only thing I would add is flaring at 30' in the 11 or 10 when you are heavy wont work, you will end up driving it on. General rule of thumb is 10% of your landing weight. IE 490,000lbs start your flare at 50', 400000lbs 40'.
Why would you say that? As a new guy on reserve at CAL, you're just going to get whatever trip someone else calls in sick for. If the guy calling in sick was scheduled to be the FO, then you get the FO seat. If the guy calling in sick was scheduled to be the relief pilot, then you get that seat. Its 50/50.
Not to be too picky, well ya I guess I am being picky but isn't 40 one ten thousanth of your weight not 10%? 40 X 10 = 400. 40 X 10,000= 400,000
Hopefully you aren't doing that on a regular basis!
It's actually more like 95/05. Unless the sick call is inside 12 hours (and even then it's not certain) a line holder will almost always drop an IRO trip to pick up an FO trip. With the electronic alerts it happens in about five minutes or less.
That is dead on what Comair is wanting to do! Take the flying at all cost, then shut the fu$ker down for $2.00 an hour more!
You total idiot. The Delta CNC negotiated your scope under direction from your MEC and ALPA National. Then your pilot group ratified the deal. The Comair pilots did not get a voice, or a vote. Why remain angry at Comair pilots for something they had no part of?
