As a general rule, how many regional pilots does it take to do the work of a mainliner on the same route?
For instance, if a mainline 737 or MD-80 size aircraft is replaced by a CRJ-200 flying the same route (but more frequency to keep the total passenger volume the same), if you were to furlough the 2 mainliners, how many RJ pilots would need to be hired to replace them? Obviously more than 2, but would it be more like 6 (CRJ-200 holds about 50 pass, 737 holds about 150) or even more?
I ask b/c I was always under the impression that, if there are enough passengers to support the 73, then it is less efficient to run the RJ. So that explains RJ's on small, feeder routes. But it seems RJ's are now creeping into routes that have the capacity to support a 73. Given that RJ pilots are paid slightly more than mainliners per passenger (There are more RJ drivers bringing in $60,000+ than there are mainliners bringing in $180,000+, right?), how is it still cheaper to run the RJ?
I'm sure I'm missing something huge and easy here, but what is it?
-Boo!
Please note I am not advocating replacing mainline with RJ. I think the opposite should be encouraged, if only so I might someday be the mainliner.
-Boo!
