DieselDragRacer
- Apr 30, 2006
This morning I attempted to track a corporate flight and found out the N-number is now blocked. Knowing the departure and origin airports, I tried searching for the flight that way to no avail which makes sense because it's "blocked" right?
For the hell of it, I searched by aircraft type and wouldn't you know the plane and its route popped up on the map. Then the flight went away. Attempting to search again via aircraft type yielded nothing. Then about 15 minutes later it would magically appear on the map of similar aircraft types. Then it went away for awhile. Then it came back.
Is this normal for a blocked flight?
