xjcaptain said:Short answer: no. Not on a CAT 1.
Tell ya what...fly the approach into Telluride (TEX), and let me know what you see when your radar altimeter gets to the appropriate HAT. That would make it self-explanatoryAmish RakeFight said:Ive seen RA's used before in 135 baron pax runs which were always CAT. I
I havent yet really been exposed to those helpful devices, but is one not allowed to really activate one for say 200'?
Aren't they installed in many aircraft that dont fly CAT II & III approaches. Is it that they can only be used as a secondary source, even though you have it set to soemthing close to the DA/MDA according to altimeter?
AC560 said:Can you legally use a radio altimeter to determine MDA on a CATI ILS or non-precision approach? I think the answer is no but just wanted some clarification.
Thanks!
MauleSkinner said:Tell ya what...fly the approach into Telluride (TEX), and let me know what you see when your radar altimeter gets to the appropriate HAT. That would make it self-explanatory
The reason it's not valid except as an aid to situational awareness on CAT I approaches is that the HAT isn't necessarily the same as the radar altitude when you get to minimums...the ground just isn't that flat.
Fly safe!
David
Amish RakeFight said:So for those who regularly use an RA for other than CAT II & III approaches, how can you effectively and safely use it as a back up.
Well, if your radar altimeter says you're 500 feet above terrain in flat country, and your baro altimeter says you've got 1200 feet to go to minimums, it's a good bet that you need to check your altimeter settings to avoid becoming a CFIT statistic...basically, a little knowlege of the area will go a long way toward making a radar altimeter a useful safety feature.Amish RakeFight said:So for those who regularly use an RA for other than CAT II & III approaches, how can you effectively and safely use it as a back up.
