safepilot24
Member
- Feb 4, 2003
Some more questions from a thankful but starving CFI:
1.) Suppose you are flying a 2000 C-172 Skyhawk that has a red beacon on the vertical tail, and a white strobe light on each wingtip, and the beacon is inop...can you still fly day VFR as per 91.205? Reg states that for small civil aircraft, certificated after 1996, that's me, aircraft must have operable, "approved aviation red or aviation white anticollision light system."
Do my white strobes count as an "approved aviation white anticollision light system?"
What about 1979 C-172's that have red flashing beacons but no strobes. I want to be legal, but display some common sense towards collision avoidance as well.
2.) Which is worse and why....Skidding spins or slipping spins? (Seems to be the hottest question on the CFI checkride right now)
3.) For C-172 Skyhawk, the PIM specifies to "increase distances 10% for each 10 degrees above standard temperature." Can I take this to be a linear relationship between performance values and temperature? (i.e, if temperature is 7 degrees above standard, increase distances 7%?)
4.) Calibrated airspeed question: CAS is IAS corrected for instrument and position errors. If you look in the C-172 PIM, there is an airspeed calibration chart that shows the following:
KIAS 40 50 60 70 80 90 100 110 120
KCAS 49 55 62 70 80 89 99 108 118
The way I interpret this is at high angle of attacks, the pitot tube is not collecting the same total pressure since it is meeting the relative wind at an angle. Calibrated and indicated are the same at 70-80 since these are critical approach speeds, and calibrated is actually slightly less at high speeds because the faster moving air across the static port experiences a significant pressure drop which makes it seem like less static pressure, thereby making the pressure difference appear to be greater. Am I correct in my assumptions? I just want to make sure I understand the "instrument and position" errors the definition is referring to. Any other position or instrument errors I should know about other than slips?
5.) Most light GA aircraft are equipped with 2-12 volt batteries connected in series. Are these considered 35 amp-hours, meaning will they run 35 amps for one hour or 70 amps for half of an hour? I am trying to gain a better understanding of how much I can run off the bat in case of alternator failure?
Thanks everyone.
Thanks everyone.
