I think that's just the military version (C-12 i think?) So far as I know the B200s rolling off the line are all under 12,500.Prof. ATP said:Sme King Air 200s are certified to have a maximum gross weight over 12,500lb, so a type rating is required.
[My 200 ground school instructor at Simuflite used this as a bar bet.]
The B200T orginally came from the factory with tip tanks a camera/drop hole and a significant max gross increase. There was also a B200CT that also included a cargo door. The 200T was primarily designed for Maritime patrol. It could be operated in the standard category without the type rating or in the restricted category with the gross weight increase, therefore requiring the type rating. My company had one for a little while used for aerial mapping. The problem is trying to find someone that is qualified to do the type ride. Very few people have a King Air 200 type.Prof. ATP said:Sme King Air 200s are certified to have a maximum gross weight over 12,500lb, so a type rating is required.
