Singlecoil
I don't reMember
- Jul 26, 2002
Anyone who has flown this airplane knows that if you go to slats extend, you get a serious balloon effect when you subsequently go to flaps 11. The usual cure is to move the flap handle very slowly to mitigate the rapid change in center of lift when the flaps are extended with the slats at mid.
However, it seems to me the Douglas engineers thought around this and designed the airplane to be configured from clean to slats mid/flaps 11 simultaneously. If the handle is moved from clean to the 11 position without stopping at the 0 position, the slats and flaps come down together, keeping the center of lift in relatively the same station on the wing.
At least that has been my take on it. I flew with a Captain recently that wouldn't comply when I asked for "Flaps 11" from the clean configuration. I had the approach and pattern planned to keep the throttles at idle until 500-1000 ft agl. The speeds for flaps 11 and slats mid are both .57/280, but the Captain said it was "really bad" to do that and "there is a reason" why we don't do that. I had never heard that before, and was unable to uncover a reference in the manual for not configuring slats and flaps simultaneously.
Does anybody else have an opinion on that one? To me, those Douglas engineers were extremely crafty. I don't need to see it in a book to tell me that the aircraft was designed to be configured in the matter I describe. When another captain first showed me you can configure that way without the balloon I had a "Eureka" moment. Clearly the airplane must have been designed with this in mind.
Am I wrong?
Am I wrong?
