Question for current flight instructors
cjscinta
Member
Hello all,
I keep my CFI updated but I haven't flown a single engine piston in a long time. I want to do a BFR and an IPC for a friend and was wondering where to find examples of the proper endorsements and some q and a, syllabus info. etc. Thanks for any help.
Heres a link to AOPA's Safety advisory to Flight Reviews
HTML:
http://www.aopa.org/asf/publications/sa03.pdf
Hope this Helps!!
Sorry that the last part is lengthy but thats the FARS for you.
§ 61.56 Flight reviews
(a) Except as provided in paragraphs (b) and (f) of this section, a flight review consists of a minimum of 1 hour of flight training and 1 hour of ground training. The review must include:
(1) A review of the current general operating and flight rules of part 91 of this chapter; and
(2) A review of those maneuvers and procedures that, at the discretion of the person giving the review, are necessary for the pilot to demonstrate the safe exercise of the privileges of the pilot certificate.
(b) Glider pilots may substitute a minimum of three instructional flights in a glider, each of which includes a flight to traffic pattern altitude, in lieu of the 1 hour of flight training required in paragraph (a) of this section.
(c) Except as provided in paragraphs (d), (e), and (g) of this section, no person may act as pilot in command of an aircraft unless, since the beginning of the 24th calendar month before the month in which that pilot acts as pilot in command, that person has—
(1) Accomplished a flight review given in an aircraft for which that pilot is rated by an authorized instructor and
(2) A logbook endorsed from an authorized instructor who gave the review certifying that the person has satisfactorily completed the review.
(d) A person who has, within the period specified in paragraph (c) of this section, passed a pilot proficiency check conducted by an examiner, an approved pilot check airman, or a U.S. Armed Force, for a pilot certificate, rating, or operating privilege need not accomplish the flight review required by this section.
(e) A person who has, within the period specified in paragraph (c) of this section, satisfactorily accomplished one or more phases of an FAA-sponsored pilot proficiency award program need not accomplish the flight review required by this section.
(f) A person who holds a current flight instructor certificate who has, within the period specified in paragraph (c) of this section, satisfactorily completed a renewal of a flight instructor certificate under the provisions in §61.197 need not accomplish the 1 hour of ground training specified in paragraph (a) of this section.
(g) A student pilot need not accomplish the flight review required by this section provided the student pilot is undergoing training for a certificate and has a current solo flight endorsement as required under §61.87 of this part.
(h) The requirements of this section may be accomplished in combination with the requirements of §61.57 and other applicable recent experience requirements at the discretion of the authorized instructor conducting the flight review.
(i) A flight simulator or flight training device may be used to meet the flight review requirements of this section subject to the following conditions:
(1) The flight simulator or flight training device must be used in accordance with an approved course conducted by a training center certificated under part 142 of this chapter.
(2) Unless the flight review is undertaken in a flight simulator that is approved for landings, the applicant must meet the takeoff and landing requirements of §61.57(a) or §61.57(b) of this part.
(3) The flight simulator or flight training device used must represent an aircraft or set of aircraft for which the pilot is rated.
AC 61-65E will have the endorsements.
For the IPC look in the Instrument PTS and there is a table showing you what Tasks need to be completed.
Also 61.57(d) is another reference for the IPC.
Hope this helps!
1. Completion of a flight review: 61.56(a) and (c)
I certify that _______________, holder of (pilot certificate type and certificate number), has satisfactorily completed a flight review on (date). (1-hour of ground and 1-hour flight training required)
2. Completion of an instrument proficiency check: 61.57(d)
I certify that _______________, holder of (pilot certificate type and certificate number), has satisfactorily completed an instrument proficiency check in a (list make and model of aircraft) on (date).
