Big Picture
Member
- Oct 1, 2005
I am relatively new to Pro Line 21 and thought maybe one of you guru's could help me out.
The situation is this: We're on vectors for the approach and ATC clears us for the GPS XX. We have been in HDG and VALT prior to the clearance. When we are cleared for the approach, we select MAP altitude in the altitude preselect and press APPR. This arms APPCH FMS1 and GP (Both white).
The problem is that APPCH FMS1 has a line through it, indicating there's a problem. It will not capture the inbound course unless I hit NAV, let it activate and then reselect APPR. When I reselect APPR, it arms APPCH FMS1 and GP as before. When it gets to the glidepath VGP activates and flies the approach as it should. During the approach FMS1 and VGP are active and APPCH FMS1 is armed with a yellow line through it.
Any thoughts as to what we're doing wrong? I should also note that all other type of approaches using VNAV guidance seem to be working properly.
Thanks.
Thanks.
