VNugget said:Controlling airspeed in a power off glide is light years beyond what a student needs to know?![]()
FlyBieWire said:I’m sure there are going to be exceptions to any rule but I like the concept of the role reversal of power and pitch as the Modes change.
VNugget said:rate of climb = (power available - power required) / weight
UndauntedFlyer said:FLIGHT PATH MODE applies when the airplane is operating on a fixed FLIGHT PATH, such as in cruise or descending on a glide path like an ILS glide slope, VASI or even a VNAV path... ALTITUDE CHANGE MODE applies when the airplane must make LARGE CHANGES IN ALTITUDE either in a climb or in a descent without concern to a particular path.
Alamanach said:Can you explain what "power available" and "power required" are?
I agree with FlyBieWire, I like the FPM/ ACM explanation too. And I think the existence FMS is a strong point in favor of Undaunted Flyer's main argument. But...
from an engineering standpoint, what makes the "fixed" flight path of FPM different from the unspecified flight path of ACM? There are similar forces and similar dynamics at play, and it is not obvious what distinguishes one flight mode from the other (in a mathematical/ physical/ engineering sense). Unless the distinction is simply that FPM is a more precise mode of flying. If that is the case... we may be back to square one.
UndauntedFlyer said:...the answer is that ACM mode always has the throttle in a fixed position such as idle or maybe 1800 RPM for descents. And then the throttle will be at takeoff or climb power for climbs. In the FPM the throttle would normally be somewhere in the middle moving as necesasry for airspeed control.
Power required is the power required to maintain level flight at any given speed. Power available is the actual power produced by the engine/prop at the moment. If the Pavailable = Prequired you're gonna be in level flight. If Pavailable exceeds Prequired, then you have excess power and you're gonna climb. If Pavailable is less than Prequired, then there's a deficiency of power and you're gonna descend.Alamanach said:Can you explain what "power available" and "power required" are?
VNugget said:If you have an engineer's aproach to things, I highly recommend this book: Aerodynamics for Naval Aviators.
Alamanach said:I read that book about ten years ago, and really got a lot out of it. It looks like I need to look through it again. Thanks.
So...what if he doesn't? What if this student pilot is working on his Sport Pilot certificate, and has no desire to fly anything except Grandpa's 7AC?UndauntedFlyer said:If a pilot wants to understand Technically Advanced Aircraft (TAA) they might as well start thinking in terms of FLIGHT PATH MODE & ALTITUDE CHANGE MODE now.
Questions or Comments are welcome.....
MauleSkinner said:So...what if he doesn't? What if this student pilot is working on his Sport Pilot certificate, and has no desire to fly anything except Grandpa's 7AC?
I may think the FAA is full of crap on a lot of things, but I do agree with the "building block" theory for training/learning, and I think it would be a little unreasonable to expect that every student pilot is going to be able to build on their experience with FMC's & autopilots.
Fly safe!
David
I'm not arguing that your technique is wrong. The "old" approach to me is the third one that you don't seem to acknowlege...that a combination of pitch and power is required to maintain the altitude and airspeed that you desire... I was taught it in the C-140, and it still works in FMC airplanes. But to say that you can't teach it properly without an FMC seems a little off.UndauntedFlyer said:New students can learn any way you want to teach them. But even though their are holes in Wolfgang's "Stick & Rudder" approach to this, people do learn notwithstanding those problems.
There are problems in the "old" approach and that is why there is always so much disagreement on how to teach this, because both ideas were correct.
Now in the FMC airplanes it is confirmed that there are two ways of controlling altitude and two ways of controlling airspeed and both must be used. This I done through the role reversals of pitch and power modes. All this must be true or how could the FMC equipped airplanes fly so perfectly.
Look at what "Flybiewire" says, quote:
He's only 15-years old and he gets it perfectly. Smart boy.
81Horse said:As to the original question: I always refer to the Aerodynamics for Naval Aviators handbook -- Power + Attitude = Performance. Understanding this relationship makes the power/altitude/pitch/airspeed debate moot.
(And IMO, Aerodynamics for Naval Aviators is an underappreciated resource in civilian flight training.)
MauleSkinner said:I'm not arguing that your technique is wrong. The "old" approach to me is the third one that you don't seem to acknowlege...that a combination of pitch and power is required to maintain the altitude and airspeed that you desire... I was taught it in the C-140, and it still works in FMC airplanes. But to say that you can't teach it properly without an FMC seems a little off.
Fly safe!
David
UndauntedFlyer said:This is truely the only correct explaination...
