Greetings,
For the technically minded, is there a certain drip rate from the underwing quick drains that will allow airflow to suck a tank dry?
Will the inside tank pressure vs. the outside pressure serve to seal a leak, say a piece of dirt trapped under the rubber plug in the drain?
Or does airflow act as a siphon, sipping out fuel until there is none left?
Would a damaged fuel vent cause a siphon in this situation where it would otherwise not cause problems?
I'm trying to figure out why one leaky sump did not drain a tank, the next one did, and the third one caused no problems. Yes, the mechanics have worked on the plane all three times.
Fly SAFE!
Jedi Nein
Fly SAFE!
Jedi Nein
