Pilot Slot Help
MEW04
Member
I am currently getting application packets together to apply at several air national guard bases for pilot slots, I have a few questions about the physical and medical history part, also any helpful suggestions for the road ahead would be appreciated! :)
Here are the medical questions:
1. In my early childhood and when I was about 17 I was diagnosed with Eczema . . .I was told that this could possibly disqualify me from the Air Force?
2. The past several years I have had several urinary track infections . . . went to see a urologist and nothing was wrong, even so . . . will this be a problem?
Thanks for your help!
My theory, and it has worked for me and others I know...
The less you put down, the better. I am not saying that you should lie about anything, but if it is not in your record already...
urinary tract infections
your post does not list your gender
if you are female, UTI's are not uncommon due to a short urethra (ex. "honeymoon cystitis")
if you are male and have had frequent UTI's, there is something likely wrong (which may not have been discovered by your urologist depending on the extent of his workup). UTI's are rare in males unless there are retained stones or an anatomic problem
