CitationLover Aw, Nuts! Joined Feb 26, 2003 Posts 3,316 Feb 16, 2007 #1 of 5 How are the Piaggio's wings deiced in flight? boots? fluid? heated wing? I saw one and it had a clean wing, no holes for fluid.
Flyoa1 Special Ed wants YOU! Joined Aug 6, 2003 Posts 53 Feb 16, 2007 #2 of 5 I sat right seat in one a long time ago, I believe its heated. Wings are made from good old Aluminum, not composite.
A avbug Well-known member Joined Dec 14, 2001 Posts 7,602 Feb 16, 2007 #3 of 5 Bleed air for the wings.
X xdays Well-known member Joined May 27, 2004 Posts 90 Feb 16, 2007 #4 of 5 Bleed air for main wings, electric heat for the forward wing, no heat for the stab.
H hdpilot50 Active member Joined Dec 23, 2006 Posts 29 Feb 17, 2007 #5 of 5 you ll notice on a lot of them to start showing some green. paint chips away on the leading edges
