Phenom and TR's
rajflyboy
From what I can tell the phenom has no TR's. What do you think of this? Is it an issue? or not? or is it just pure rinky dink?
I know that TR's are not counted in the stopping distance on most part 25 certificated aircraft.
What about those few days a year with a wet runway, snow covered runway, etc. when it would be really nice to have TR's?
Landing distance at MLW is only 2600 ft, according to Embraer's web site. Even 135 60% margin is only 4300 ft. I have no idea what the contaminated numbers look like, but performance w/o TRs looks pretty good.
It's another potential maintenance issue with TRs. Don't need really them, although they (ERJ) saved quite a bit of money not putting them on.
What in the hell does transformer/rectifiers have to do with stopping distance?!
My engines have fire extinguishers. Never have to use them, does that mean they're not needed?
We are talking about planes that are not equipped with TR's, so you're comparing apples to oranges. There's a reason why some aircraft have no TR's, and that's because they are simply not needed. If you have TR's, use them. I've flown a/c without them and did just fine. (knocks on wood).
It's all about economics. Installing several hundred pounds of equipment, hydraulics, cables, and other assorted hardware reduces the useful load on a light jet by more than one pax. yes, TRs are preferable. So would hooks and barriers at every airport. That ain't happening either.
If conditions are not conducive to safe operations, don't go or pick another destination. I've never had a passenger second guess my decision, nor has company given me any backlash.
A 60 has TRs. A CJ4 doesn't. Which stops in a shorter distance, TRs included?
You tell me-I have no idea. Also compare usefull loads, range, etc. Which one would be more affected by adding a couple hundred pounds more equipment? And how many corporate jets include TRs in landing distance computations? What's the cost with or without? Point is, EMB 300 does just fine in most airports any fractional goes. Even with Part 135 planning restrictions. In the minds of both sides of the equation, both parties really don't have an issue with lack of TRs.
One can argue all jets should have at least 3 engines to avoid second segment issues at places like Aspen, Eagle or Telluride. OEMs like to sell more jets, while pax like to buy more bang for the buck. There is a cut off for extra expense that all are willing to accept.
I would have loved TRs a few months back in the Cj2. Sure, we stopped in time...but it was way closer than I like it to be. TRs "probably" would have helped. That said, we can put 1102# on the plane (pax + bags) before we hit MZFW. Toss even 150# of TR equipment into the mix and it's even worse.
Our dry landing distance at typical landing weights is in the 2800' range. When the runway gets contaminated it goes up significantly from there. But if we don't have enough runway for the book numbers, we don't go.
Put me in the "they would be nice and I'd love to have them, but aren't really necessary" camp. While we're at it...get those damn Thrust Attenuator paddles off of the back, too. They're nothing but a maintenance hog and a way to keep the brakes cool for taxi. Give me a lower idle and less hydraulic crap to break.
-mini
