PA-28-200R Landing gear
IrishFlyer
Wacky and Waving
Hi Guys,
Sorry but the POH for this aircraft is useless. I have been getting to many contradicting answers regarding the gear system for said aircraft and I need a quick definitive answer. How many micro switches and where? And isn’t there only one squat switch on the left main gear?
Also have any of you guys heard about aircraft manufacturers designing a slight twist in the tail and or vertical stabilizer to counteract torque effects?
Thanks very much,
IF
Gear....
P-28R-200 has
A.squatswich on left main gear.(disables gear operation on ground)
B.Microswitch on the throttle quadrant. (Activates horn Below 14" MP with gear up.)
C.Microswitch on flaps. (Activates horn beyond 10 degrees flaps with gear up.)
D You have three down-limit switches and obviously three up-limit switches.
These basically tell the hydraulic pump when to stop pumping hydraulic fluid to the actuator cylinders on all three gears.
I've heard of the vertical stabilizer thing. Whether it's found on the Arrow? I don't know.
I've also heard mounting the engine at a slight angle off-sets torque.
Which manufacturers do this? I don't know.
I've heard of this, but in a bit different context. If you take a look at the Arrow's prop from the side, you'll see that the longitudinal axis of the airplane is not 100% perpendicular to the prop arc. In fact, the engine appears that it's tilted slightly down. This was done to keep the propeller somewhat perpendicular to the relative wind while the aircraft is flying with a normal AOA. This could help reduce p-factor, but I don't think torque would be affected.
Safe to say we're all familiar with the yaw left/pitch up characteristics for a clockwise rotating propeller when the engine is at high power. It's caused by several factors including slip stream & P-factor. Rudder, fin &/or engine thrust line offsets are common methods used to reduce the yaw &/or pitch couples associated with propeller slipstream & P-factor.
Usually the correction is arranged so that it cancels the yaw at cruise speed & power setting(s). Of course the corrective effect from aerodynamic solutions may still be significant even when the power setting is low and the correction is not needed ie with an offset fin or rudder. This means that the correction will be insufficient to completely counter the yaw at low speed/high power settings, and overcorrect at high speed/high power settings - unless there's a cockpit adjustable rudder trim which lets the pilot increase or decrease the rudder's yawing force without having to hold continuous pressure on the pedals.
A type of pressure activated switch. It has a protrusion that is held in an extended position by spring pressure. When a moving part reaches it's desired position a contact pad presses against the protrusion on the microswitch, pushing it in. The part of the protrusion inside the switch can be wired so that an electrical contact is made with the protrusion extended and broken when pressed in, or so there is no circuit in the extended position & a circuit is made when the switch is pressed in.
If you've ever seen the switch on your car door that activates the interior light when the door is opened then you've seen a type of microswitch.
The Beech Musketeer does this for sure, don't know of many others off hand.
The PA-28-200 has the engine mounted slightly off center, a higher AOI on the left wing, and a twisted vertical stabilizer, all to help counter left-turning tendencies (mainly torque)...where to find this i have no clue though, but if you stand in front of the airplane and look closely you can definately see the engine offset to the left. Can't really see the different AOIs or angled stabilizer though.
Engine offset on various types I'm familiar with. It's the differential mainplane incidence that I'm querying. I'm not sure that there is sufficient torque on these low powered types to warrant it. If it's there then it would be noticeable as a roll to the right in a power off glide but I've never seen it. As far as I'm aware the rigger's incidence is the same from left to right wing on these types - that's why I was interested in the source of this asymmetric incidence information.
I've heard that the most but I've also heard that its not actually 14" MP but rather a position in the quadrant. What do you guys think?
thats correct, in our fleet of arrows, there are some that will give you the horn at 16-17" and some that you need full idle to get the horn. usually it will get written up once it is very obvious and mx will change the setting on the throttle quadrant. it is a lot cheaper and easier to put the microswitch in this manner rather than figure out some fancy gadget that will run off the actual MP to sense <14"
Hi,
Thanks for all the interesting responses. Quick question:
"a higher AOI on the left wing"
I understand what the AOI is but can someone explain how this helps to counteract left turning tendencies.
"engine mounted slightly off center"
I presume it is mounted off to the right if looking from the rear of the aircraft?
"and a twisted vertical stabilizer"
Again I presume it is twisted off to the right, correct?
Sorry for being persistent I simply dont want to start telling the examiner a load of bs in the oral.
Thanks again,
IF
greyhound said:
P-28R-200 has
One small problem with the up limit switch. On the arrow's the uplimt switch does not turn off the hydraulic pump. The Pump will maintain a positive pressure then shut off around 1500 PSI & maintains it. The up limit switchs turn off the Gear unsafe light. If for one reason the hydraulic system looses pressure, the gear will fall, Deactivating the Up limit switch & illuminating the gear unsafe light.
OK, I dug out the Arrow manual, because I was thinking the same thing (about the motor pressure switch)
Referencing the Electrical Schematic in the Arrow Manual we have:
3 up limit switches.
3 down limit swiches
1 squat switch
1 pressure switch for the motor
1 throttle quadrant switch
On certain models, 1 switch for the Automatic Gear Down Actuator.
On certain models without the above AGDA switch, 1 flap switch that sounds the horn with 10 degrees flap and gear still up.
As a matter of interest -- during flight the gear may drop a little as the system loses pressure -- this trips the pressure motor switch which pumps the gear back up
I'm just making sure I understand this correctly. The three "down" microswitches will stop the pump when the gear is down and locked. They will also cause the gear position indicator lights to show illuminate. The gear "up" microswitches do not stop the pump. The pump stops itself at a certain PSI. Is that correct?
greyhound said:
P-28R-200 has
Stand 10 feet back from the spinner and look at the spacing in relation to the cowling. The engine is obviously offset a bit.
Ok direct from pa28r-200 information manual for s/n 28r-7435001 - 28r-7635545.
Some a/c incorporate a pressure sensing device in the system whech lowers the gear regardless of gear selector position, depending upond airspeed & engine power.
Now, if the pressure sensor notices a loss of pressure, it should activate the pump to increase the pressure. Positive pressure keeps the gear up. The sensor should notice a drop in pressure before there is enough movement in the gear to deactivate the micro switch.
So you are correct. The gear up switch does not shut the hydraulic power pack off.
Neither do the gear down microswitches as far as I'm aware.
--as an aside, you should watch (listen) for a pump which does not shut off; usually indicates a leak in the system (and will wear out that expensive pump if not repaired). It will stay on to keep the gear (and pressure) up; the gear may stay all the way up, but the pressure will be too low for the pump to shut off.
Then what shuts the pump off at the down limit? My manual shows a pressure switch only in the side of the system that's pressurized when gear is going up.
Three down limit switches will shutoff the pump going down. ~1800 PSI (not up limit switches) will shut the pump off on the way up.
