I recently encountered an obstacle DP that simply says “RWY 5, Climbing left turn direct ABC VOR.” At what altitude do you start your turn? Is it as soon as practicable? Is it at 400 ft agl since if there is no published ODP, obstacle departure procedures are based on the pilot climbing to 400 ft above the departure end of the runway before making an initial turn? For discussion purposes, let’s assume a 0/0 takeoff under part 91 in mountainous terrain.
Also, say you are 30 nm out on a feeder route inbound to the IAF in uncontrolled airspace. ATC says “cleared approach” and you are currently at 5000 ft. The feeder route has an MEA of 4000 ft. Do you have do descend right away to 4000 since you have been cleared approach, or can you stay higher until closer to your IAF?
