Rogue5
Adult Swim junkie
- Jul 16, 2002
NTSB PRESS RELEASE
National Transportation Safety Board
Washington, DC 20594
FOR IMMEDIATE RELEASE: May 2, 2006
SB-06-27
FUEL STARVATION CITED AS CAUSE OF CARGO AIRPLANE CRASH
Washington, DC - The National Transportation Safety Board
today determined that the probable cause of the crash of an
AT cargo airplane, on August 13, 2004, was "fuel
starvation resulting from the captain's decision not to
follow approved fuel crossfeed procedures."
Contributing to the accident were "the captain's inadequate
preflight planning, his subsequent distraction during the
flight, and his late initiation of the in-range checklist."
Further contributing to the accident, the Board said, was
"the flight crew's failure to monitor the fuel gauges and to
recognize that the airplane's changing handling
characteristics were caused by fuel imbalance."
"Here again we see the tragedy that can result when time-
tested procedures are not respected," said NTSB Acting
Chairman Mark V. Rosenker. "The accident also points up the
severe consequences that can follow when the operator of an
aircraft, or any other vehicle, becomes distracted."
The accident airplane, a Convair 580, was operating as a DHL
Express cargo flight from Memphis TN, when it crashed on
approach to landing at Cincinnati/Northern Kentucky
International Airport, in Covington KY. The first officer
was killed and the captain was injured. The airplane was
destroyed by crash impact forces.
Examination of the wreckage revealed no evidence of any pre-
crash problems with the airplane's engines, systems or
structures. There were no indications that the airplane's
cargo had shifted during the flight. Investigators also
determined that there was sufficient fuel on board for the
flight from Memphis to Covington.
Cockpit voice recorder information indicated that the
captain began fuel crossfeed operations about 50 minutes
into the flight, and that he allowed it to continue
unmonitored for almost 30 minutes. Post-accident
examination of the wreckage revealed that, contrary to
approved procedures, the fuel tank shutoff valve had been
left open during the crossfeed operations, which allowed
fuel transfer from the left tank to the right tank.
The Board concluded that, during the airplane's descent to
landing, the fuel in the left tank, which was providing fuel
to both engines, was exhausted because both engine-driven
fuel pumps drew air from the left tank into the fuel system
instead of fuel from the right tank, which led to a dual
engine flameout caused by fuel starvation.
Consequently, the Board recommended that the FAA issue a
flight standards information bulletin to familiarize Convair
580 operators with the circumstances of the AT
accident, including the importance of closing the fuel tank
shutoff valve for the tank not being used during crossfeed
operations. The Board further recommended that Convair 580
operators be required to use the same output pressure
settings on their left and right fuel pumps.
The Board, noting that additional details about the flight
crew's actions after the loss of engine power would have
aided the investigation, reiterated a previous
recommendation to the FAA (A-99-16), which called for
retrofitting airplanes with independently powered cockpit
voice recorders.
The texts of these recommendations and a synopsis of the
report can be found on the NTSB web site at www.ntsb.gov.
The complete report will be released at a later date.
NTSB Media Contact: Paul Schlamm (202) 314-6100
This message is delivered to you as a free service from the
National Transportation Safety Board.
You may unsubscribe at any time at
http://www.ntsb.gov/registration/registration.htm
An archive of press releases is available at
http://www.ntsb.gov/pressrel/pressrel.htm
Current job opportunities with the NTSB are listed at
http://www.ntsb.gov/vacancies/listing.htm
For questions/problems, contact [email protected]
NTSB PRESS RELEASE
SB-06-27
voice recorders.
