Are there any Hawaiin Air/NWA/ATA Boeing 767/757 pilots viewing this post that can shed some light on how you dispatch builds ETP's for flights from either KSEA/KPDX to PHNL or other island destinations? I am suspicious of some of the data I see coming from my computer generated flight planning services and wondering if on a typical KSEA to PHNL flight are using KPDX as the first half ETP airport, or are you dropping down to KSFO/KOAK as you proceed along your south westerly track towards the islands? At some point around mid ocean it would appear that KSFO would replace KPDX as the better (in time) alternate assuming winds and airport weather do not become the defining factor. For the purpose of this question I am using the Boeing "Critical Fuel Scenario" at 10,000' as outlined in AC120-42A (ETOPS). Also what kind of speeds are you using for your 10,000' diversion.
Thanks in advance. We are flying a B757 (Part 91) and although we observe many ETOPS procedures, we are not required to be an FAA approved ETOPS operator.
