http://careers.northgrum.com/ExternalHorizonsWeb/getJobPostDetail.do?sequenceNumber=94473
Pilot in command of company owned or operated turbine engined aircraft. Employment is based on the ability to pass FAA & Company Class 1 Flight Physical with no waivers. U.S. citizenship is required. Must be eligible for DoD security clearance.
Minimum flight hours experience required is 3,000 hours with 1,000 hours Turboprop, 250 hours in the last 12 months and FAR 135 experience. BE-1900 type rating preferred.
FAA ATP certificate required. Preferred education/special skills as noted in Northrop SPP and Northrop Grumman Aviation Division Operations Manual.
Perform other duties as assigned by management. Minimum years of experience: N/A
Preferred years of experience: N/A
Preferred Education: BS
Special Tools Required: Aircraft Compatible Headset
Special Skill/Certification Requirements: FAA ATP Certificate
