Northrop Grumman BE-1900 pilot @ KHHR
FL420
Blues vs. Birds-Tailhook
http://careers.northgrum.com/ExternalHorizonsWeb/getJobPostDetail.do?sequenceNumber=94474
Job Detail Flight Operations | Pilot 3 Turboprop Planes | Hawthorne, CA / USA | Corporate
Posting ID: 0090/037039
Description:
Pilot in command of company owned or operated turbine engined aircraft. Employment is based on the ability to pass FAA & Company Class 1 Flight Physical with no waivers. U.S. citizenship is required. Must be eligible for DoD clearance. Minimum flight hours experience required is 3,000 hours with 1,000 hours Turboprop, 250 hours in the last 12 months and FAR 135 experience. BE-1900 type rating preferred. FAA ATP certificate required. Preferred education/special skills as noted in Northrop SPP and Northrop Grumman Aviation Division Operations Manual. Perform other duties as assigned by management. Minimum years of experience: N/A Preferred years of experience: N/A Preferred Education: BS Special Skill/Certification Requirements: FAA ATP Certificate Required Special Tools: Aircraft Compatible Headset
Description:
What does it pay?
B190Captain said:
What does it pay?
If you are asking me, at the risk of sounding flip, you know as much as I do about the job after reading the ad.
I have not heard good things about NG aviation. Stuff like work your a$$ off and never home thanks to 135 stuff on the side. However, the shuttle may be different, but who knows?
