Title: 737 Captain Company: Northern Air Cargo Inc. Product/Service: Location: Anchorage, AK Required Travel: None Job Type: Full-time Employment Type: Permanent Description: Commands aircraft and crew. Represents the Company from departure until return to crew base. Responsible for the safety of their Flight Crewmembers and their aircraft, as well as the safe transportation of freight and mail by performing the following duties. Determines weather at en route destinations and alternate destinations; evaluates extent of current and forecast weather conditions for safe and efficient operation of flight. Ascertains that the aircraft is properly pre-flighted and is airworthy for the assigned flight. Evaluates the conditions affecting the flight to determine the necessary fuel and oil requirements. Coordinates servicing of the aircraft with the flight engineer. Oversees and validates that the aircraft is loaded and balanced according to approved standards and within approved flight manual limitations. Conducts the flight from the command position and makes all necessary decisions during the assigned flight. Provides the command authority to conduct the operations IAW FAA 121.537. Maintains communications and rapport with customers and station agents while away from home station. Make recommendations to management regarding upgrading of systems, procedures, safety issues, etc., through proper completion of required forms as well as contributing personal insight. Loads and unloads the aircraft when away from domicile. Requirements: Required skills and experience: High school diploma or general education degree (GED). Frequently lift and/or move up to 70 pounds. Valid drivers license with good driving record. FAA First Class medical. Airline Transport Certificate with B737 type rating. Previous B737 Captain experience with an FAR part 121 carrier required. Previous FAR part 121 cargo experience preferred. Passport required. Company Benefits: Contact Information: N/AFax: 907/243-3859Northern Air Cargo Inc. US Preferred Response Method:Please fax resume to: 907/243-3859
Didn't I read that NAC's new owners had ordered some 737s as replacment aircraft? Search for threads, I know I've read about NAC either on this forum or APC. One of the forums has a member who is an NAC pilot. When I flew in AK many years ago Northern always liked guys who were currently living and flying there.
