NJA Quality of Life
blueridge71
Outlasted two companies
I know that the pay under the new NJ contract is exceptional, but what about the quality of life?
Specifically, I'm curious about reserve and standby. My current company situation with standby is starting to look like FLOPS where you are either on rest, flying, or standing by.
How are you treated by scheduling and the company in general?
They like to get a full days work out of you, whether that be flying or stand by. I did spend this last Sunday on stand by at the hotel all day watching football and then airlined home the next morning, day 7. I was driving up into my driveway by 1000. Not typical, but does happen.
As far as standby at the FBO, the new contract has some sections addressing it. I'm sure I will be corrected if I am wrong, but after 3 hours of cumulative standby for the day, you start earning overtime. At 7 hours, it goes to double time.
Not sure what you mean by reserve. We can be scheduled stand by at home, hotel, or FBO. There is no reserve per se.
I'm sure some others will chime in as well.
thanks, Sky King. That is what I was looking for.
We can do airport standby all day for all seven days of the tour with no extra compensation.
Hotel reserve doesn't bother me.
What I meant by reserve was the flex schedules. I've heard those referred to as reserve.
How about overtime? Is that readily available if desired?
Just notify the company with a 30-day notice of your base change. You can change as often as you want but the minimum time you must spend at your new base is 30 days.
Does unionization make a difference in this case?
Yes. Anyone else earning overtime for standby at the FBO beyond 3 hours? That was something negotiated. Certainly wasn't anything required to be given by the company for any reason.
Actually, there are quite a few things in this section of the contract where the union made a big difference for us and our quality of life. Too many to list here.
But yes, the union made a difference in our standby (reserve) scheduling. (a positive difference)
Old reserve schedule is gone as of Feb. 1. With that schedule you could bid 2 sets of 2 hard days, and then the company was able to use you when they wanted throughout the month within some contractual limitations.
The new schedule is an 18 day schedule that is awarded by the 15th of the month prior. You will bid on tour length and days off using a PBS system yet to be implemented. The company will work those bids into a schedule that gets awarded by the 15th of the month and is not changeable by the company.
There will be a new schedule as of Feb. which will work more like a reserve schedule. It's a max 15 day work month in which the company can send you on a tour when they want, but it can be no longer than 5 days and will be followed by mandatory days off. On any day you are eligible for a tour, you will find out the night before by 1800L whether or not they are using you and what your show time will be.
Hope that helps.
Are they still going to have the 7on/7off schedules?
Are you able to switch from any of the schedule options at any time? For example, this month I want the 7 on 7 off, next the 15 day flex.
I know it was briefly mentioned, but if you are on the 7 on 7 off schedule, you travel home on the first and last day correct? If so, is that all you do on the first and last days, or do you/could you have an assignment on the first or last day?
There will be three bidding periods per year. So, once on a schedule, you are on it for 4 months.
You do travel on your first and last day. Quite often, you will have some other duty on those days as well.
Disclaimer: These are my own interpretations and do not reflect the views or opinions of IBT 1108 or NJA.
I just wanted to make a slight clarification to this statement.
You might be sitting at the FBO for 14 hours IF you have a good crew and good airplane. This is now called "flight asset" and is what we used to call "airport standby" or "hot spare."
"Standby" is now what we used to call "FRDA (Flight Ready Duty Assignment)". This occurs when you do not have a full crew or a good airplane. In these cases the company has 3 free hours in order to figure out what to do with you, or to get the plane fixed. Anything over 3 hours of "standby" in a duty period and you will start to receive OT. Anything over 7 hours, and you start getting double OT. Also, the hours are not consecutive. So if you break at 0800, they get the plane fixed by 0900, then you have spent 1 hour of "standby" for the duty period. If you then break at 1200, and the plane isn't fixed until 1500, then you have spent 4 total hours on "standby." You would have earned 1 hour of OT in this example.
"Reserve" is now being on duty at rest accommodations. (Home, hotel).
Hope that helps.
