New known ice definition
Nolife
Tired Member
Anyone hear of the proposed definition change of "Known Icing" by the Northeastern Regional FAA. The definition supposedly will be changed to if freezing conditions exit and there is high relative humidity that will constitute "known icing." Anyone have additional info? A search of the faa.gov website turned up nothing.
AOPA is pushing back on that right now, vehemently.
This is what we've been saying for some time, however, and everybody fights it. If conditions exist that could produce ice, even if ice isn't being produced, even if it isn't being reported, even if it isn't being forecast, you have known ice, because you're in conditions known to be conducive to produce ice.
Avbug,
No disagreement here ... except: The current furor is about an interpretation letter that effectively woud change the definition of (to use your words) "If conditions exist that could produce ice". Previously "conditions that could produce ice" were determined in some quantitative manner by meterologists. Now, I haven't seen the actual leter itself, but as I understand it fom AOPA, the letter changes that to any time hte temp is below freezing and the relative humidity is high. If nothing else, that raises the question of what is "high relative humidity" ? Anything over 90%? 80%? 70%? High is a pretty vauge term to apply to limits on an objective quantity. One might conclude that according to the letter, it is not illegal to fly in a cloud when the OAT is freezing or lower, unless your aircraft is certificated for known icing.
I would agree with this change if it was'nt high relative humidity. What does that mean? Are we going to check temp/dew point charts along the way? How about freezing (or 34-35F what ever it is) then visible moisture. IE, Fog, clouds, precip etc.
Interesting.
I read the letter of interpretation which started this. Not only does the letter raise the ambiguous question of what constitutes "high relative humidity", but it also states explicitly that any time you are in a cloud and the temp is freezing or below, you are in known icing conditions.
from the letter:
"Since clouds are a form of visible moisture, flying through clouds at an altitude that is at of below freezing would constitute flight into known icing conditions."
SO there you have it. unlless your airplane is certificated for known icing conditions, it's illegal to fly through a cloud when it's cold.
For those of you interested in reading this letter, go to this link on the AOPA website.
http://www.aopa.org/whatsnew/newsitems/2006/061127icing.html
Follow the link to AOPA's Letter to FAA counsel. The original Letter of Interpretation is appended to AOPA's letter.
Having read the opinion, I my impression is that the unfortunate "high humidity" language is more about the "known" part than the icing part. In other words, if a pilot chooses to fly on a day when the temperatures are cold and the temperature-dewpoint spread is narrow, if clouds form ice forms, the pilot will be in no position to claim that the icing encountered was not "known."
That doesn't make it much better, but it does keep it in more or less in line with existing NTSB caselaw that forecast weather conditions that are conducive to icing, even without icing-specific forecasts or reports, is enough to nail the pilot.
How about this:
Lets teach pilots to be smart about ice from day one and NOT MESS WITH IT if you shouldn't.
Then the FAA can stop flying my airplane.
-mini
The FAA isn't flying your airplane. You are. However, you are doing so only in accordance with the regulations and policies of the FAA, who provides you the authorization to fly your airplane, and the conditions and circumstances under which you may fly it, as well as regulates the airspace in which you fly, and dictates the specifics regarding the aircraft itself, it's condition, and how it's operated. That will not change, as without the FAA, you don't have the privilege to operate the aircraft in the first place.
What is needed is better understanding of the regulation and policy, and in this case, some further dialogue and quite possibly revisitation regarding the legal counsel opinion.
If they keep changing the regulations that give me the privilege to operate the aircraft safely, they might as well just fly it.
But no...we can't have pilots making decisions.
-mini
