New caution for pilots landing on wet runways
Airtran Fanatic
Recommendation comes after plane overran runway and boy died
Friday, January 27, 2006; Posted: 2:13 p.m. EST (19:13 GMT)
WASHINGTON (CNN) -- The National Transportation Safety Board is urging that commercial airplane pilots change the way they calculate stopping distances on slippery runways to avoid a crash, such as the one in Chicago that killed a child.
"We believe this recommendation needs the immediate attention of the FAA since we will be experiencing winter weather conditions in many areas of our nation for several more months to come," NTSB Acting Chairman Mark V. Rosenker was quoted in a news release issued by the board.
The NTSB wants the Federal Aviation Administration to prohibit airlines from calculating the effect of a plane's thrust reversers into the formula that figures what distance is needed to land when runways are slick.
The urgent recommendation comes from an NTSB investigation into what caused a Southwest Airlines flight, landing at Midway Airport in a snowstorm on December 8, to roll off the end of the runway -- where it tore through two fences and stopped in an intersection, hitting two cars. A 6-year-old boy in one of the cars was killed.
The pilots had used a laptop computer to calculate how far the plane needed to go to land, the NTSB said. When the runway's condition was entered as "wet-poor," the computer calculated they would be able to stop with 30 feet to spare.
But the calculations took into consideration that engine thrust reversers would be deployed at touchdown. Instead, the NTSB said, "flight data recorder information revealed that the thrust reversers were not deployed until 18 seconds after touchdown, at which point there was only about 1,000 feet of usable runway remaining."
Without the thrust reversers, the calculation would have shown a safe landing was not possible, it said.
"As a result," the board said in its recommendation letter to the FAA, "a single event, the delayed deployment of the thrust reversers, can lead to an unsafe condition, as it did in this accident."
The NTSB said the FAA already prohibits the inclusion of thrust reversers in calculations in some cases.
the investigation is on going..
[quote/]...when the runway's condition was entered as "wet-poor," the computer calculated they would be able to stop with 30 feet to spare.
The NTSB said the FAA already prohibits the inclusion of thrust reversers in calculations in some cases.[/quote]
I thought required landing distance was calculated using no reverse thrust, and under part 121, the require landing distance can be no more than 60% of the runway length. Also, multiply this number by 1.15 for wet runway ops. What 30 feet are they talking about?
Whoever changed the rules to allow for this on the latest Boeings should be hung too.
Cardinal said:
30 feet at 130kts, that's about one blink or so....
That's 30 within the requirement to land within 60% of the usable runway I'm assuming. At 130 knots you'd travel 3250 feet in 18 seconds. I'm not sure when manual braking began or how effective it was. Without the TR's deploying promptly those guys were between a rock and a hard place. It will be interesting to see how much emphasis the NTSB places on perfromance requirements.
Hi!
I didn't know that thrust reversers were allowed at all to calculate the stopping distance.
What R the conditions where you ARE allowed to use TRs in your landing data?
Cliff
ABY
PS-My plane doesn't have any (some of ours used to have them, but they were removed), but I know our DC-9s LD can't be calculated using TRs in the equation.
These landing distance rules are the source of much confusion. So here is my take (might as well add to the confusion). First you have to distinguish between dry and wet. We all know that you have the 60 or 70% safety factor thrown in and also assume no reverse thrust. No, here is where is gets tricky: A contaminated runway is a whole different ball of wax. You can still plan a flight to a destination with a runway that you are unable to land within the 60 or 70% distance. You just have to include an alternate. Now when you arrive at your destination, you can forget about the 60 or 70 rule. On a contaminated runway, you can take into account reverse thrust, and you just have to be able to stop in the available landing distance. This has no margin for error. This is nuts! I imagine the rules will be changing in the future.
Washington, D.C. 20594
Safety Recommendation
Date: January 27, 2006
In reply refer to: A-06-16
Honorable Marion Blakey Administrator
Washington, D.C. 20591
On December 8, 2005, about 1914 central standard time, Southwest Airlines flight 1248, a Boeing 737-7H4, N471WN, landed on runway 31C at Chicago Midway Airport (MDW), Chicago, Illinois. The runway was contaminated with snow. The airplane departed the end of the runway and rolled through a blast fence and a perimeter fence and then into traffic on an off-airport street. The airplane came to a stop after impacting two cars, which resulted in the death of a child passenger in one of the vehicles. Of the 2 flight crewmembers, 3 flight attendants, and 98 passengers aboard the airplane, 5 reported minor injuries, and the airplane was substantially damaged. The flight was operating under the provisions of 14 Code of Federal Regulations Part 121 as a commercial passenger flight from Baltimore/Washington International Thurgood Marshall Airport, Baltimore, Maryland. Instrument meteorological conditions prevailed for the flight. The National Transportation Safety Board believes that the urgent recommendation contained in this letter requires immediate attention to restore landing safety margins on contaminated runways.
Snow began to fall in the area surrounding MDW about 5 hours before the accident. While the flight was en route and holding to land at MDW, the flight crew obtained updated weather information and runway braking action reports from air traffic control. On the basis of this information, the flight crew planned for fair braking action on landing on runway 31C. The runway was last cleared and treated about 45 minutes before the accident. About 30 minutes before the accident, airport ground personnel performed a runway friction measurement, which indicated that the runway friction was “good.” About 1/8 to 1/4 inch of scattered snow was on the runway when the airplane touched down.
Expected Landing Performance on Contaminated Runways
The flight crew used an on-board laptop performance computer (OPC) provided in the cockpit of Southwest Airlines’ airplanes to calculate expected landing performance. For landing performance calculations, flight crews enter flight specific data into the OPC, including the expected landing runway, wind speed and direction, airplane gross weight at touchdown, and the reported runway braking action. The 737-700 OPC is programmed to assume that the engine thrust reversers will be deployed on touchdown1 and to calculate the stopping margin (the runway distance remaining from the front of the nose wheel to the end of the runway pavement after the airplane comes to a stop). The OPC then alerts flight crews if the remaining runway distance is not sufficient for the airplane to land and completely stop on the runway under the selected weather and runway conditions.
The flight crew entered weather data into the OPC and input WET-FAIR as the runway braking condition. The OPC calculated that the airplane would be able to land and completely stop on runway 31C under the selected weather and runway conditions with about 560 feet of runway remaining.2 During postaccident interviews, the flight crewmembers told Safety Board investigators that they considered 560 feet to be an acceptable safety margin and, therefore, decided to execute the landing.
The assumption that engine thrust reversers would be deployed on touchdown is consistent with Southwest Airlines’ Flight Operations Manual, which states that, when landing under less than good braking conditions, the thrust reversers are to be used as soon as possible during the landing roll and are to be applied with the brakes. However, flight data recorder data revealed that about 18 seconds passed from the time the airplane touched down to the time the thrust reversers were deployed; at that point, only about 1,000 feet of usable runway remained. During postaccident interviews, the captain stated that he attempted to immediately deploy the thrust reversers but that he was unable to do so. According to the first fficer, at some point during the rollout, he noticed that the thrust reversers were not deployed, and he then reached over and deployed them. The late deployment of the thrust reversers almost completely negated the stopping distance benefit that had been expected because of the use of the thrust reversers. The airplane departed the end of runway 31C at a ground speed of about 50 knots.
Reverse Thrust Usage Credit
The Federal Aviation Administration (FAA) does not allow the use of the reverse thrust credit when determining dispatch landing distances. Further, the decrease in stopping distance resulting from thrust reverser use (which increases the safety margin) had typically been used to offset other variables that could significantly degrade stopping performance.
However, the FAA allows the reverse thrust credit to be used in calculating en route operational landing distances for some transport-category airplanes, such as the accident airplane, a 737-700. Accordingly, when using the reverse thrust credit for contaminated runways, the required runway length for 737-700 model airplanes is about 1,000 feet less than the required runway length without the reverse thrust credit. The OPCs of Southwest Airlines’ 737-300 and -500 model airplanes do not use the reverse thrust credit; therefore, these model airplanes have a greater landing safety margin. In this accident, when the thrust reversers were not (or could not be) used in a timely manner, the airplane could not be stopped on the runway because of the absence of this extra safety margin.
1 Boeing 737-300 and -500 model airplanes are not programmed with this assumption.
2 The flight crew also input WET-POOR as the runway braking condition. The OPC calculated that a 30-foot
runway margin would remain.
If the reverse thrust credit had not been factored into the stopping distance calculations made by the OPC, it would have indicated that a safe landing on runway 31C was not possible under a braking condition of either fair or poor. The Safety Board is concerned that the landing distance safety margin is significantly reduced on a contaminated runway when the reverse thrust credit is allowed in landing stopping distance calculations. As a result, a single event, the delayed deployment of the thrust reversers, can lead to an unsafe condition, as it did in this accident. The Safety Board concludes that the safety margin must be restored to those airplanes for which thereverse thrust credit is currently allowed in landing performance calculations.
Therefore, the National Transportation Safety Board recommends that the Federal Aviation Administration:
Immediately prohibit all 14 Code of Federal Regulations Part 121 operators from using the reverse thrust credit in landing performance calculations.
(A-06-16) Urgent
Acting Chairman ROSENKER and Members ENGLEMAN CONNERS, HERSMAN,
and HIGGINS concurred with this recommendation.
By: Mark V. Rosenker
Acting Chairman
as70co/Midway/Midway Urgent Rec.doc
KSears drafted 1/9/06; revised 1/12/06;revised 1/20; final 1/26/06
Draft proofread by _____________________________
Revisions : 0 | Posted: 1/27/2006 6:19:03 PM | IP: Recorded
Previous Page Next Page
Jump to: Select Forum SWAPA News SWAPA Links Pilot Lounge Negotiations Discussion Contract Retirement / Benefits Scheduling Safety Home Access Retirement Hotel Issues Lost & Found Trade Board - Captain Trade Board - FO
Contact Us | Back Home | Privacy Statement | Forum Rules
Ideal BB Version: 0.1.4.3Message forum software powered by the Ideal BB
Forum software by:
Not really. They weren't figuring factored landing distance. That is done before the flight takes off. In the air you're dealing with how many feet it will take to get stopped. And on that plane, it includes thrust reversers.
That's for dispatch use only. Actual landing distance can be used once in the air.
