NetJets ultranav?
pilot370
I thought I read awhile back that NetJets was using the Ultranav program for its aircraft. Are they or will they use some form of it when the EFB's start to be used?
You're making some pretty huge assumptions with the EFB statement. Who knows if they are coming our way. There aren't even any rumors about us getting those again.
UltraNav is not all that's it's cracked up to be. Quite abit of bad info. Many times what is spewed out by UltraNav cannot be backed up with the AFM.
Climb gradients, tempertures, dry/wet runways, contaminated runways, ect..ect...ect...I'll pull the book out if its all the same and use those numbers. I've never had an Assist. Chief Pilot argue against any number I happen to produce from the AFM.
Didnt know if it was true or not about the EFB's. I just say the statement on airlinepilotcentral.com.
Electronic flight bags to be installed across fleet in 10-year deal with Rockwell Collins
