NetJets Interview question
captain007
Climb Gradient into %.
Is it Ft/nm / 6079? For what ground speed?
Isn't there also an easier way?
Thanks for all the info.
Climb gradient is usually expressed in percent or ft/NM. If you have a gradient that's in "percent", you can convert it to "ft/NM" by multiplying the gradient by 6076.1. Conversely, you can convert a gradient that's expressed in ft/NM to "percent" by dividing by 6076.1 and multiplying the result by 100.
For instance, 4.2% is 255 ft/NM (0.042 x 6076.1 = 255).
Second example: 400 ft/NM is a gradient of 6.58% (400/6076.1*100).
to add to this....if you're then asked "well what's my VSI going to read with a Single Engine"?
Gradient % x ground speed = Ft/Min.
ex. 6.3% x 140 kts (beechjet) = 882 FPM. (VSI with Single Engine)
