Need help persuading my boss!
  • Thread starter Thread starter HMR
  • Watchers Watchers 5
HMR
I Live by the River.
My boss has been looking for a new plane for the past 4 months. He wants a twin cessna (340, 414, or 421). His plan is to fly it for a year and buy a King Air C90. Last week our board of directors informed us that the company's profits and travel needs are growing faster than expected. They want to get the C90 now (yahoo!). Neither of us have ever flown one and he's conviced that a C90 would be too hard for us to fly.
I'd like to hear from any of you with C90 experience. Are they any harder to fly than a 414 (a plane we're both comfortable in)? I have 1200tt/400multi. My boss has about the same and we'd both be required to attend Flight Safety.
Thanks,
HMR
From everything I have heard, King Airs are "easy" to fly and a total pilots' plane. I'm pretty sure the 414 is bigger PITA than a C90. If the BOD is willing to spend $$$ for a C90, it's the way to go.
Show your boss the difference between the safety record for turbine vs. piston twins. If you lose an engine you'd be better off in the King Air.
The B model is the one with four blades, and a nice airplane to fly. Systems aren't hard, either. I was able to teach them to a friend in three days, using the Flightsafety manual as my text.
You're really going to enjoy flying this airplane.
King Air
For what it's worth, I have one hour in C90s. If this is any guide at all, it flew very much like an A36 Bonanza and B55 and B58 Barons. I have about 300 hours total split between the latter three aircraft.
You will have no problem flying the King Air and FlightSafety's training will be an added plus.
Pretty benign airplane. Should not be a problem at all with your experience level. You do need to pay very careful attention during training to the care and feeding of turbine engines. Hot sections are very expensive. It's not hard, just different.
I'm relatively new to the King Air C90, but i've found that it is not as hard to learn as I one thought. Systems aren't any more complicated than they would be in a 400 series Cessna, ALOT more reliable than any piston, and an engine failure is almost a non-event. Heck, the thing feathers itself and even applies rudder boost to help you keep it level! Someone with your experience should't have any trouble learning the King Air, and anyone with the ability to learn will do fine if they go through school at Flight Safety.
If your company belongs to MBAA, have them do a cost benefit analasys for you and they will tell you which one best suits your needs.
My guess is that with your experience the insurance cost for the C90 will kill the deal. Until either of you get to around 3000TT and 500 turbine you might not not even be able to find anyone that will insure the airplane. Same for any turbine. I know, I know. The turbine is safer and more reliable. It also costs a whole lot more to fix if you f*ck it up.
The plane you see to the left (until I change my pic) is one of the easiest to fly aircraft I have ever been in. It is very safe, docile and FUN. I haven't flown a twin Cessna, but highly recommend the BE90. Beechcraft are by far my favorite planes. I can't say enough good things about them.
It's not a matter of "hard." Hard implies difficulty, and moving in to turbine equipment will be easy in terms of difficulty.
A bigger issue is one of insurability, and experience. Total time is entirely meaningless. More important is what you've been doing for those 1,200 hours. Your time is very low, to be sure, but what you have done during that time, and what you have learned from it, counts for a lot. If it's all been in a J-3 cub, that won't be a lot of use transitioning to a King Air.
How will your insurance carrier view your past experience? Are you up to speed on instruments? Have you flown your approaches at a fast enough speed, and how are you on systems knowledge? Are you serious about your flying? These things count for a lot. It's not a matter of a king air being a hard airplane to fly; it isn't. (What airplane is??). It's a matter of being able to do it; availability, insurance, judgement, basic flying skills.
Remember too, that at a reasonably low experience level, the airplane may be far more capable than you. That is, it may be equipped and capable of going places that you are not. A big judgement issue is knowing your limitations and respecting them. Don't let that equipment, or the boss, take you places or in conditions you shouldn't be.
We operate a C90B, E90, as well as the older A90 and all three are by far the easiest of any turbine multi-engine aircraft out there. Our newer C90B being my favorite- The PT6A-21's are great engines and extremely reliable. The only concern that you may have is the insurance requirements since I know our insurance company is somewhat strict and they want to see quite a few hours of "turbine" time in the logbook as well as initial/recurrent training before they will insure us as PIC. "hard" though should be left out of the equation when your company decides on the next aircraft you purchase since the 90 is by far the easiest of the King Air fleet to operate. Blue line is 108, Vmca is 80, stall 78 (KIAS) calculated at MTOW of 10,100 lbs if that tells you something. Raytheon manufactures a very nice, reliable, safe, and very easy plane to operate so if you decide to purchase one I would bet you would enjoy it to the utmost...
Any other questions feel free to ask
350
Righto
Caveman made the point,,,,, what are the insurance limits for one of you.
You are probably fine as F/o but one of you needs turbine time, probably in the 500 hour area, at least 250 along with TT etc.
Airplane is like big Aztec. Reliable, tough, solid. More like truck than your Cessna although I have not flown later models.
Only thing I disliked was they are sort of short and crosswinds were a pain at where we were based as that was all we had. The 100 we had was easier.
My CFI got a corporate gig in a B90 with about 50 hours ME and maybe 5000 flight instruction given. He was in his 50's and had been instructing for a long time.
He went to Flight Safety, and they insured him to fly the plane. That simple.
You are going to find, just as everyone has told you, it is a dream to fly. Very straight forward operation. Really fun.
Like wise when it comes to insurance that is another story. Of course you must do the FlightSafety thing or even SimuFlight which is a little cheaper. With your time your insurance company will probably require an experiened pilot to fly with you for at least a Min. of 25 hours or up to maybe a hundred hours. No big deal. Well worth the safety aspect of it. Once you get the plane on line your boss will kick himself for not making the transition sooner. The maintenance costs are going to be different. Remember two things 1. Beechcraft means premium. 2. There is not much to do until it breaks and when it does it is not cheap. The dependability is far and away worth the bucks. Go for it
Good Luck to you and let us know how you like it
Best Wishes..
Insurance comments continued
Thought I might hijack this conversation and ask more about current insurance requirements. What are operators finding out about their insurance requirements after 9/11, especially those who have renewed since Jan? We have been operating a late model BE-B200 Pt 135 & 91. Myself, currently about 700 hrs in the BE-B200, 900 turbine, 1900 Twin, 4650 TT, ATP/CFI (no accidents/incidents). We have always tried to operate 2 pilots (we have a co-pilot with a little more than half the above times), but would like the flexibility to operate single-pilot when needed. Our insurance renewed in FEB. It went up about 105% with stipulations that we operate 2 pilots on 91 & 135 and the "walk-on" requirements just for co-pilots is 1000 TT/500 twin. We reduced our preminum by reducing our liability and hull but is still about $12,000 more than we were paying. Policy is through USAIG. Boss wants to "shop around", but what I realize is that there are only a handful of underwriters around and unless you are up for renewal they can't quote you. Is this true and is this what others are seeing? Is there a consumer complaint board? The insurance companies are running scared and seem to be taking advantage of 9/11.
