Flymach2 said:Hi...
However, U.S. conventional type aircraft will have engines that rotate counter-clockwise when viewed from the cockpit. So, placing a greater thrust-line on the descending part of the prop arc, you can see where,(in relation to the longitudinal axis of the airplane), the lines of thrust are the greatest.
So, as a result, the right engine,(when viewed from the cockpit), would be the critical engine because if this engine failed, it would have the most adverse effect on aircraft directional control.
Um....other way around, man. Clockwise rotation when viewed from the cockpit is the norm, and the left engine is critical for the reasons you mentioned. Remember left-turning tendency? The engine is always trying to turn left, thus a single engine on the right wing is worst.
Those may be the 3 that the FAA seems to think makes the biggest difference....but what about Power? Are you saying VMC is the same at Idle as it is at Max? Or that a student doesn't need to know if he reduces power, Vmc essentially goes away? Why would those factors be included for certification if they didn't affect Vmc?jetalc said:Part 23 has to do with aircraft certification, and does not elaborate on aerodynamics. The FAA is not necessarily saying that all those factors affect Vmc - this is a common misunderstanding, and too many MEI's make their students memorize this ridiculous list. According to the Flight Training Handbook, Chapter 16, the FAA states only three factors that affect Vmc (whether we agree or not is irrelevant) - CG, Density Altitude and Angle of Bank. That's it. End of story. The configuration that a new aircraft has to be in while determining its PUBLISHED Vmc has very little to do with the factors affecting Vmc...
Anyone else have any references where it actually states that the factors that affect Vmc are anything more than these three? I've been looking for 15+ years, and haven't found any others...
Similar to Part 23, I don't see anything about how those factors affect Vmc - I have my own theories to rationalize that configuration, but I still can't find anywhere where it is stated that these factors affect Vmc. I feel that the FAA, in the interests of safety and FULL education, should re-vamp the way it discusses Vmc, possibly to include statements like "anything that decreases rudder effectiveness will increase Vmc" or "these factors affect Vmc most significantly" instead of apparently limiting the factors to those three.IP076 said:Those may be the 3 that the FAA seems to think makes the biggest difference....but what about Power? Are you saying VMC is the same at Idle as it is at Max? Or that a student doesn't need to know if he reduces power, Vmc essentially goes away? Why would those factors be included for certification if they didn't affect Vmc?
http://av-info.faa.gov/data/practicalteststandard/faa-s-8081-12b.pdf
On PDF page 114 of that document (Commercial PTS) it states that the applicant must:
2. Configures the airplane at VSSE/VYSE, as appropriate—
a. Landing gear retracted.
b. Flaps set for takeoff.
c. Cowl flaps set for takeoff.
d. Trim set for takeoff.
e. Propellers set for high RPM.
f. Power on critical engine reduced to idle.
g. Power on operating engine set to takeoff or maximum
available power.
In that statement alone I would think one would need to know why each item is configured as stated, unless of course, we just teach robots, which that landings thread is starting to imply......
Also you could imply needing to know more than those 3 from pages 84 and 113 of that PDF file.
I think, and I also think most FAA people would agree, that a commercial multi pilot should have a idea of how items such as Flaps, Gear, Props, and Power affect the controllability and performance of an aircraft while operating single engine.
