I have this paradontal (paradental) (spelling anyone) pocket between two of my teeth.
(apparently the dentist says it comes from grinding my teeth which comes from STRESS which he says mostly comes from the persons job. Gee I wonder how that could be? Thanks Airways!!! Like its not enough you kicked me out of the left seat, took 27,000/year from me, keep pushing me backwards, now your making small holes between my teeth which makes me wakeup in the middle of the night in pain like somebody is shoving needles in the nerves around my teeth.)
Anyway the dentist recommends that I use mouth wash after every meal. I have been doing this while at home (while not at work) and it keeps the pain away, but now I need to take it on the road with me because the problem has become more frequent. The dentist says the better I keep it clean the faster the gum will heal and thus the problem. One the road I was using BioTene a mouthwash that he recommended that has no alcahol. At home I use Listerine which does.
Basically BioTene sux donkey balls. It tastes like watered down milk with alittle mint added. The Listerne is stronger and does a better job of cleaning anything that gets into the pocket. The dentist even backed this up.
So my question - will the alcahol in the Listerine show up if I get tested one the job after I use it? My dentist seems to think it won't even register. In the past 4 years I've been selected for ramdom testing 3 times. Once in ABE for a pee test and twice in SYR, both were breath test which obviously blew 0 both times or I wouldn't be here. What do you guyts think? Is the listeine Safe? Or should I suck it up and stick with the BioTene which sux?
